It is currently Tue Aug 04, 2026 12:35 pm
Post Posted: Mon May 07, 2012 4:55 pm
so i put a g16a (carby) into my sierra about a month or 2 ago..
the rear main crank seal was leaking so i put a new rear seal and sump gasket sealant on..
engine has been runin fine for a month and no oil leaks anywhere, plenty of power and runs superquiet.
just got home and there is oil leaking all over rear main & front crank seal 8O engine is still quiet
and oil,water is fine..
option 1 : should i pull it out and get bottom end rebuilt hoping its just the crank and no (common)cracks in the block (as water and oil is not mixed)
option 2 : i can get another runing g16A for 3-$400, throw it in and hope that its a good engine.
Post Posted: Mon May 07, 2012 5:01 pm
did you use genuine seals?
Post Posted: Mon May 07, 2012 5:09 pm
i only replaced the rear seal and sump as there was no leaks near the front. cant remember if they were genuine or not but were from suzisport so i would think they were proven quality.
the main reason im worried is both front and rear seal have started leaking at the same time??
but the engine seems to still be runin fine..
Vehicle: 03 Jimny
Post Posted: Mon May 07, 2012 5:26 pm
Did u put them in right? Didnt damage them at all?. I say they ain't genuine seals.
Users browsing this forum: No registered users and 259 guests
