so i put a g16a (carby) into my sierra about a month or 2 ago..
the rear main crank seal was leaking so i put a new rear seal and sump gasket sealant on..
engine has been runin fine for a month and no oil leaks anywhere, plenty of power and runs superquiet.
just got home and there is oil leaking all over rear main & front crank seal
engine is still quiet
and oil,water is fine..
option 1 : should i pull it out and get bottom end rebuilt hoping its just the crank and no (common)cracks in the block (as water and oil is not mixed)
option 2 : i can get another runing g16A for 3-$400, throw it in and hope that its a good engine.
