It is currently Mon Sep 21, 2026 2:59 pm
Vehicle: 84 Lwb Ute
Post Posted: Wed May 09, 2012 7:57 pm
Hey all have a nt 84 lwb that I put a 1.3 in. I also have the donor car which was a factory nt 1.3 5 speed. I need to know if the cars have the same diff ratios? Would I be better off putting the nt 1.3 diff centers in my ute to stop it revving on the high way.
Post Posted: Wed May 09, 2012 8:01 pm
No.
The 88 1.3 will have 3.9 ratios. The 84 1L will have 4.11's. But the centres are larger in the 1.3, so they are not interchangable.
Swap the whole NT diff into the 1L.
Vehicle: 84 Lwb Ute
Post Posted: Wed May 09, 2012 8:06 pm
Really that's for your help. Will this stop it revving on the highway?
Post Posted: Wed May 09, 2012 8:15 pm
If you fit the diffs from the donor car, it will be revving at the rpm's suzuki intended the 1.3L to do.
EDIT: Not quite. The 1L transfer is 12% lower in high range, so swap in the donor t-fer case aswell. To make it easier, swap the jack, and front drive shafts too. You will either need a 1.3 LWB rear shaft, or swp the yokes from your donor rear shaft onto the LWB rear shaft.
Vehicle: 84 Lwb Ute
Post Posted: Wed May 09, 2012 8:17 pm
Yer that will be better. The 1.0 doffs are to low geared and revs it's guts out with the 1.3 in it. I will just swap the whole diffs over. Are the wt 1.3 centers the same as the nt 1.3 centers.
Post Posted: Wed May 09, 2012 8:18 pm
Same size. The WT's are 3.7:1, so a little better for highway than the NT centres.
Users browsing this forum: No registered users and 136 guests
