It is currently Sat Aug 01, 2026 11:59 pm
Post Posted: Fri May 11, 2012 5:22 pm
want to run chromoly and im trying to work out the front diff situation.... being 26 spline.
dont have any money really atm and i know i can get diff centers cheap, question is, has anyone run a rear
diff center in a front diff to accomodate 26 spline cv's ????
thanks guys
Post Posted: Fri May 11, 2012 5:54 pm
What car are you talking about?
Post Posted: Fri May 11, 2012 6:02 pm
I could be wrong, but Pretty sure you can't run a rear center in the front of a Sierra because of the way the r&p are designed/machined.
You can use the side gears and put them in the front though.
Post Posted: Fri May 11, 2012 6:06 pm
I think you might be wrong.
R&P are the same front and rear. and RD88 (rear air locker) can be installed in a front or rear carrier.
Post Posted: Fri May 11, 2012 6:11 pm
Yes your right there. I no there the same but the op is asking if you can put in the hole rear center/third member into the front to make it 26 spline.
What I think he is asking is, if he get a rear carrier and just bolt it into the front housing. Doing this wouldn't the r&p be running the wrong way?
Post Posted: Fri May 11, 2012 6:19 pm
so i can just get myself some rear diff side gears and run them in the front, allowing me to run chromo's ??
thanks guys
Post Posted: Fri May 11, 2012 6:22 pm
On a NT 1.3 Sierra with standard 4 pinion diff centers yes
Anything else, for the purpose of what you are asking, no you wont be able to, if its a wt 1.3 Sierra with 3.7 gears, just go get another rear center
Vehicle: '96 LWB trayback
Post Posted: Fri May 11, 2012 6:26 pm
Assuming it's a sierra (WT):
If your aim is to just get cromo axles to fit (ie: you require 26 spline side gears) bolting in a stock rear centre of the same ratio is an ideal solution.
Post Posted: Fri May 11, 2012 6:28 pm
I had a rear in the front of mine.
Post Posted: Fri May 11, 2012 6:29 pm
Nope. It's all the same front and rear. A rear third member bolted straight into the front still turns the right way.
Post Posted: Fri May 11, 2012 6:32 pm
^ Yeah.
Think about it. Looking from the transfer to the rear diff when the shaft is turning clockwise, if you look at the front it will be turning counter clockwise.
Post Posted: Fri May 11, 2012 6:41 pm
It's just some thing I read one day, I can't explain what I read so I'll just shut up. carry on :D
Post Posted: Fri May 11, 2012 6:43 pm
NT Sierra run 4 pinion front AND rear.
WT run a 2 pinion front and a 4 pinion rear.
4 pinion is much stronger than 2 pinion.
All 1.3 diffs are 22 spline front.... 26 spline rear.
Rear centre will bolt straight into front housing.
Rear side gears (26spl) can be fitted to a 4 pinion carrier and then fitted to a WT front centre if you want to run CrMo axles.
Post Posted: Fri May 11, 2012 6:50 pm
Any really old parts have been stressed one for many years,
can break easy if stressed the other way,
which is why we don't hi rev and dump clutch or steer too hard, in reverse.
And why when using 2nd hand parts, we try to fit them up in same positions when we can.
This may include using 2nd hand CV's too
This is possibly what your refering to.
But Steves right (it can happen :thefinger: ) about diff turning same way in front or rear.
Post Posted: Fri May 11, 2012 7:02 pm
Yes kinda what I was trying to say.
Post Posted: Fri May 11, 2012 10:44 pm
thanks guys
Hell yes should of been the answer.... :wink:
Post Posted: Sat May 12, 2012 5:47 am
thanks guys
STEKKY'S BACK!
Post Posted: Sat May 12, 2012 5:58 am
:D 8) :lol: Hi Stekky.
Just put a whole rear centre of the same ratio in the front.
Users browsing this forum: No registered users and 1223 guests
