It is currently Sun Aug 02, 2026 10:00 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Vehicle: 1.3 Tin Top
Post Posted: Tue Jul 10, 2012 7:11 am
I'm doing some future planning for when Bruno goes bang.
Now I can't really go without my car for anymore then a week.
I was thinking of doing a g16 Carb conversion to cut down on costs, don't really need loads of power and cbf with FI
Now I was just had a brainwave. What if a buy a second g13 and put a g16 head on it??
Will this have any performance gain?
My thinking is I can buy and rebuild the second engine over a month or so then just swap em one weekend.
And I won't have to worry about engineering?
Opionions, thoughts and ideas would be greatly appreciated :peaceout:
Post Posted: Tue Jul 10, 2012 10:34 am
g13b is gti btw thats twin cam efi
Post Posted: Tue Jul 10, 2012 1:48 pm
Did I miss something, what has that got to do with what he just asked??
And isn't a coily engine a G13B (G13Ba) which is a single cam 8 valve
Post Posted: Tue Jul 10, 2012 2:51 pm
sorry i always thought it was a 13b. my bad its 13ba.
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu Jul 12, 2012 8:44 am
I don't think it will much difference there might be for flow thou I'm not sure how diffrent the g16a head is I havnt had experience with the 1.6 head ,I do know the g13 head has some hidden power in it if u put the work and shave the head and port and polish it also there some dead spots within the head wich if u fill or weld (were the valve guide s run through ) and reshape could possible realy help ,the g13ba is a non interference engine so u can actually in theory shave a lot off the head but only if the bottom end can with stand the extra comp. Who knows about the g16 head are they better in many ways.
Green? greeeen is nice !
Post Posted: Thu Jul 12, 2012 9:17 am
You will spend a lot of money trying to get a 1300 head to flow anywhere near as well as a 1600 head. Unless you really know what you are doing (read performance cylinder head specialist) don't waste your time wrecking a head.
Post Posted: Thu Jul 12, 2012 9:47 am
Where did you get that idea from?
What makes an engine a G13B - the engine number prefix?
What would you say if I told you I have two 1.3 engines here, both have G13B engine number prefixes - one IS a 16V DOHC EFI from a '90 Swift GTi, the other is an 8V SOHC carburetted in a 93 5 door Swift hatch, yes, it is the original engine, yes, I've owned it from new?
What would you say if I told you I've seen a Swift GTi where the engine number started with a G13K prefix?
Post Posted: Thu Jul 12, 2012 10:16 am
That was my thinking exactly. Id rather not mess around too much with a head.
Maybe just a port and polish of a 1600 head.
Will a 1300 block with a 1600 head be more efficient?
Post Posted: Thu Jul 12, 2012 11:01 am
Err because he is right?
They may use the same block, but the general term for a Gti motor is g13b, g13bb for jimny(early models), g13a for nt and g13ba for wt and g13collapse.at.90k for coilies.
Post Posted: Thu Jul 12, 2012 11:23 am
Generalization isn't necessarily 100% right. All sorts of oddball stuff has come out of the Suzuki factory.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Thu Jul 12, 2012 12:26 pm
That is true JrZook, but the reason I am making the connection is because in his original post and topic heading he mentions G13B vs G16a, which most guys on here would think as GTI, therefore he isnt going to get correct answers until someone points it out, as Jonno has done. My CA has L18 stamped on the engine block.
Post Posted: Thu Jul 12, 2012 1:21 pm
The confusion comes from the heading which does say G13B V G16A and you are right in saying that when someone says G13B people usually think twin cam GTI, but when you read what he says in the post he is explains that he is talking about non efi engines not twin cam efi gti.
To be precise the coily single cam 8 valve 1298cc engine is a G13B, it is cast with G13B on the block, but unlike the G13B Gti Twin Cam the coily G13B has an extra letter stamped in the engine number and the letter is an "A" so it is commonly known as a G13BA.
Post Posted: Thu Jul 12, 2012 1:35 pm
Sounds like a good idea can u post pics of the head throughout so o can look at for my next engine build:)
Post Posted: Thu Jul 12, 2012 1:40 pm
I think the block I have is a g13b and it came out of a 92 auto golden barina. And its was its original engine I may be wrong its been built since but its still only got 8 valves for know any way
Post Posted: Thu Jul 12, 2012 1:48 pm
Seriously mate if you don't know what you are doing don't mess with the 1600 head either, you are more likely to make it worse not better.
And yes the 1600 head, manifold and carbie will improve the 1300 but don't expect it to be better than a 1600.
Post Posted: Thu Jul 12, 2012 1:56 pm
my plan is to buy another engine and do the work on it, so i can learn.
i dont expect a 1300 to perform better i just dont want to do a 1600 conversion as it will need engineering and that will mean i cant drive it on my p's
Post Posted: Thu Jul 12, 2012 2:42 pm
I am not saying don't do up an engine what I am saying is there are lots of things you can do while still staying within the means of a home workshop, modifying cylinder heads is a specialist field, there are a handfull of people around the country that really know what they are doing in this field, you can read all the books you like but it takes years of experience and specialist equipment to modify cylinder heads for performance, it is done by trial and error and can cost thousands of dollars in labour to get results. I know of a fellow who spent around over $1000 on a 1300 head and in the end it flowed nearly as good as a 1600 head and that was at a place in Brisbane that specialised in cylinder heads. I am saying dont try running before you can walk, forget porting, polishing etc, bolt on a good 1600 head, mild cam, carbie and extractors and enjoy.
Post Posted: Thu Jul 12, 2012 2:56 pm
Just a thought u recon it would be cheaper to do gti conversion or a 1.8 transplant
Post Posted: Thu Jul 12, 2012 3:01 pm
what 1.8?
Post Posted: Thu Jul 12, 2012 4:30 pm
Baleno motor apparently
Post Posted: Thu Jul 12, 2012 4:54 pm
Like i said, dont want to do a transplant as that requires engineering then makes it illegal to drive on p's
Ok thanks 2stroker. i will go down that path. will 1.3 extractors fit the 1.6 or will i need to modify some
Post Posted: Thu Jul 12, 2012 6:16 pm
Sorry mate I missed that
Post Posted: Thu Jul 12, 2012 9:46 pm
I will start hunting down a second 1.3 block
Post Posted: Fri Jul 13, 2012 3:37 am
Two questions for you ...
First - what makes him right?
And if you feel he is right, perhaps you (or he), would care to explain the anomalies I described - I own, and have owned from new, a Swift with an 8V SOHC, carburetted engine, with a G13B engine number prefix - you can take my word for it, this is the original engine, original head, original carburettor - if you have access to the Suzuki dealer databases, I'll provide you with the chassis number, and you can look that up, and get from the manufacturer, the engine number and the specification of the vehicle as shipped from the factory.
Second - do you really think that a g13a from an nt and a g13b from a GTi use the same engine block - or was that a slip?
Post Posted: Fri Jul 13, 2012 4:49 am
If you go for the G16A 8V head then get the cam too as it has a little more duration and lift.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Fri Jul 13, 2012 6:24 am
X2
Vehicle: LJ50V, SJ70
Post Posted: Fri Jul 13, 2012 6:53 am
2stroker wrote:
To be precise ........
To be precise, the G13A block is designed to run a 77mm stroke crank for a 1324cc displacement, while the G13B block is designed for a 75.5mm stroke giving 1298cc. The blocks are different castings to allow the 1.5mm difference in deck height and are NOT a designation of the specific type of head (8V/16V, Carb/Efi, SOHC/DOHC) fitted, although there were only certain combinations factory fitted.
Post Posted: Fri Jul 13, 2012 7:32 am
that's what I thought as well ,
Post Posted: Fri Jul 13, 2012 8:23 am
You'll get no argument from me there - I will however point out that the "factory fitted" combinations may vary from one market to the next.
Brenno? jonno_racing??
Post Posted: Fri Jul 13, 2012 11:23 am
the 1.8 is a different fish, Its a J motor.
Users browsing this forum: No registered users and 67 guests
