| Author |
Message |
midlife zook
Vehicle: 89 swb sj50 widetrack
 Posted: Wed Jul 11, 2012 9:54 pm |
hi have a 89 swb sj50 and after changing to new suspension i still have a sag on the drivers side of around 15mm.dose not sound like much but frustraiting . thought it could be the stabilizer bar ? any ideas or help would be cool
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed Jul 11, 2012 9:56 pm |
Pretty common. It is the springs not the sway bar. Do a search on 'Sierra lean'
midlife zook
 Posted: Wed Jul 11, 2012 10:43 pm |
cool just did the search and makes me feel better that it is quite common . ill try shifting weight like the battery to the passenger side or get a bigger second battery.
alien
 Posted: Wed Jul 11, 2012 11:23 pm |
shift the driver to the passengers side =)
midlife zook
 Posted: Wed Jul 11, 2012 11:30 pm |
NOW thats a idea !! better idea would be make it a center single seater.but dont think thats legal !
Trypt
Vehicle: 1.3 Tin Top
 Posted: Thu Jul 12, 2012 2:26 pm |
It only gets worse as the springs settle... just live with it. If u tilt ur head a little or park on a slight side angle you wont notice it
KEENSY85
Joined: Wed May 09, 2012 12:46 am Posts: 1742 Location: north brisbane
Vehicle: 1985 lwb sierra UTE
 Posted: Thu Jul 12, 2012 2:46 pm |
Do u have ur old springs couldn't u just stick another leaf in on that side.
_________________ Green? greeeen is nice !
Oldzkool
Vehicle: Looking at buying a Zook!
 Posted: Fri Jul 13, 2012 3:01 pm |
has there been any good remedy to this problem yet? koz if the lean is herpies,then my cars got full blown aids! i got close to a 2" lean (drivers side)
Tyron
Vehicle: ***
 Posted: Fri Jul 13, 2012 3:17 pm |
I know it may not be this, and it's a pain in the ass. Sometimes the front springs for sierras they write on them drivers/passanger. if not measure them and put the longer one on the drivers side. sometimes they're not the exact same I spent months with my car leaning turned out to be a bent chassis. Is it as bad as the car on the right?
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Fri Jul 13, 2012 4:35 pm |
Yep that is a valid comment did you make sure springs went in right side. They are not longer side to side, the drivers side spring has more arch in it.
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Fri Jul 13, 2012 5:25 pm |
Tyron wrote: I spent months with my car leaning turned out to be a bent chassis.
Post a pic of the bend in your chassis! Interested to see where it was
_________________ Lil Foot!
http://tiny.cc/gtsw1
KEENSY85
 Posted: Fri Jul 13, 2012 6:02 pm |
Tyron wrote: I know it may not be this, and it's a pain in the ass. Sometimes the front springs for sierras they write on them drivers/passanger. if not measure them and put the longer one on the drivers side. sometimes they're not the exact same I spent months with my car leaning turned out to be a bent chassis. Is it as bad as the car on the right?  My Coily chassis was like that I was pissed  till I worked it out
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Fri Jul 13, 2012 6:31 pm |
Oldzkool wrote: has there been any good remedy to this problem yet? koz if the lean is herpies,then my cars got full blown aids! i got close to a 2" lean (drivers side) Mines about to get the springs rebuilt, but its sitting almost 4" lower on the right. Remedy would be moving weight to the left side, but this isn't that simple. Heavier spring rates on the drivers side will help, be it through thicker leafs or more of them. More arch in the DS springs will help, but eventually there just going to sag again.
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Fri Jul 13, 2012 6:34 pm |
JrZook wrote: Tyron wrote: I spent months with my car leaning turned out to be a bent chassis.
Post a pic of the bend in your chassis! Interested to see where it was I don't think Sierra chassis are that straight from the factory. They sure do flex a bit on articulation. If the chassis was bent on the one in that pic then I'd say it's only half the problem, I've seen worse Sierra lean on chassis that were fine.
want33s
 Posted: Fri Jul 13, 2012 6:36 pm |
In Snow White I had a standard rear spring in the LH front and a standard rear plus a 2nd leaf in the RH to counter the lean and drivers side load.
Tyron
Vehicle: ***
 Posted: Fri Jul 13, 2012 6:52 pm |
GRPABT1 wrote: JrZook wrote: Tyron wrote: I spent months with my car leaning turned out to be a bent chassis.
Post a pic of the bend in your chassis! Interested to see where it was I don't think Sierra chassis are that straight from the factory. They sure do flex a bit on articulation. If the chassis was bent on the one in that pic then I'd say it's only half the problem, I've seen worse Sierra lean on chassis that were fine. Near the firewall behing the pedals the mount was bent down Near the front of the chassis where the front hanger is located the right was up 3 cm's from the left.
midlife zook
 Posted: Fri Jul 13, 2012 10:10 pm |
I have measured the springs and the mounts.it apears that the drivers side rear front spring mount is slightly higher than the left.or it could be the left is lower than the right ? who knows .have decided to relocate the main battery to the passenger side tosit next to the second battery.also found taking the spare tire of makes a difference so may relocate the apare to the centre of the tailgate.will see how that goes. just dont like the idea of different spring rates .
when you consider that the spare wheel,battery steering components plus the driver on one side and nothing on the passenger side its no wonder they sag.the left hand drive version dosnt appear to have the same issue.has to be the wieght on one side.
want33s
 Posted: Fri Jul 13, 2012 10:37 pm |
midlife zook wrote: just dont like the idea of different spring rates .
Why not? You would be surprised how many cars have heavier springs on one side.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Fri Jul 13, 2012 10:53 pm |
Mine sits flat, to get it that way I removed the smallest leaf out of the passenger side spring pack. As a bonus it makes passengers look like fat bastards
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
midlife zook
 Posted: Sun Jul 15, 2012 7:20 pm |
well spent the weekend moving stuff and it appears to work .wieghed all the stuff (2 batterys,spare tyre ) .so we will see how we go.
