It is currently Thu Sep 17, 2026 11:01 am
Vehicle: SJ70 1993
Post Posted: Fri Jul 13, 2012 10:20 am
From what i found in other posts, not a good idea?
I was to gear down more and thought it would be a good solution but there are no easy ways to implent it.
Are my easiest options gearing down my low in my t-case and gearing down my diffs (i run 33s)?
Lock, Drop and roll
Post Posted: Fri Jul 13, 2012 11:19 am
33's?
6.5's in the transfer.
Vehicle: MG410 Gypsy
Post Posted: Fri Jul 13, 2012 11:54 am
33's?
You wont look back!! great mod for a suzuki with big tyres!
Post Posted: Fri Jul 13, 2012 12:03 pm
6.5's will be the easiest.
Otherwise vit gbox with transfer, to sierra transfer
This will be a ton of work and this will mean the gearbox will be longer, shorter rear tailshaft, if you still have room for one in a swb.
Some inspiration might be "kens lj" built by "Joeblow"
Vehicle: SJ70 1993
Post Posted: Fri Jul 13, 2012 12:33 pm
Cheers. yeah i know there would be alot of work but didnt know if there were easy bolt ins or compatable components.
But its all good i got 6.5s but wouldnt mine it lower
Lock, Drop and roll
Post Posted: Fri Jul 13, 2012 12:38 pm
Twin transfer will keep your highway revs at they are now. Alot will be custom to hold the sierra transfer square with the vit transfer
Otherwise diff gears, Many ratio's avaliable from sierra's, front of vits, jimny rears and aftermarket etc. Highway revs will go up!
Post Posted: Fri Jul 13, 2012 8:50 pm
You can get lower than 6.5 gears for transfer.. 8.00:1
What diffs are you running now?
If you are WT then 3.7... You can fit NT 3.9 or Vitara 4.6 or even 5.12.
Users browsing this forum: No registered users and 163 guests
