| Author |
Message |
suzukikid
Joined: Sun Jan 14, 2007 10:30 pm Posts: 2803 Location: Melton Victoria!
 Posted: Sat Jul 14, 2012 12:40 pm |
was talking too a mate that im goin chromos..... and hewas sayin that for his jeep you can get a warn hub that has a sleeve in there that breaks as the weak point instead of cvs etc....then you just buy this part in the hub that is the weak spot....
can you get these for zooks? are they worth it? anyone tryed them?
_________________ back in a built sierra!
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Sat Jul 14, 2012 1:01 pm |
They aren't sleeves, they are dowels.
I'm not sure that warn hubs for sierras have dowels. And if they do, you'd still need to drill the holes in the hub for the dowels to locate.
But.... this could be done with OEM hubs too.
_________________ 2013 GV 1998 SV420 ute
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Sat Jul 14, 2012 2:17 pm |
suzukikid wrote: was talking too a mate that im goin chromos..... and hewas sayin that for his jeep you can get a warn hub that has a sleeve in there that breaks as the weak point instead of cvs etc....then you just buy this part in the hub that is the weak spot.... Isn't the weak spot on CroMo Sierra CVs the groove cut in the short side next to the spline at the diff end, for this very reason? Then you replace the shaft - not the shafts and CV. Also, if it was a Jeep Wrangler - they have uni-joints instead of CVs...
suzukikid
 Posted: Sat Jul 14, 2012 2:54 pm |
OEM hubs what are they?
and reubs it was a wrangler we know they dont have cvs....now i read what i wrote it does sould like we where sayin they did!haha
more just saying they break something easy instead of something internal!
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Sat Jul 14, 2012 3:15 pm |
OEM= Original Equipment Manufacturer i.e. standard hubs.
suzukikid
 Posted: Sat Jul 14, 2012 3:35 pm |
ah righto! how would wou put a dowel into a standard one?
zukmeista
 Posted: Sun Jul 15, 2012 2:08 pm |
Don't even bother thinking about it, just use it and if the bolts break put stronger ones in.
christover1
Joined: Tue Jul 15, 2008 11:30 pm Posts: 8203 Location: Melbourne
 Posted: Sun Jul 15, 2012 2:15 pm |
Hub fuses used to be available for Sierras, but I never saw anyone using them. They were dear, and had to save a lot of cv's to pay for themselves. Changing a cv becomes easy with practise anyway
HarryHoudini
Joined: Fri Jul 01, 2011 12:34 am Posts: 359 Location: Northern NSW Australia.
Vehicle: Coily.
 Posted: Sun Jul 15, 2012 2:37 pm |
suzukikid wrote: OEM hubs what are they? OEM as already stated are supposed to be sourced from the original manufacturer but in reality can be just copies from our friendly Chinese factories.
_________________ Regards All from far Northern NSW.
