It is currently Sat Aug 01, 2026 3:35 pm
Post Posted: Sat Jul 14, 2012 12:40 pm
was talking too a mate that im goin chromos..... and hewas sayin that for his jeep you can get a warn hub that has a sleeve in there that breaks as the weak point instead of cvs etc....then you just buy this part in the hub that is the weak spot....
can you get these for zooks? are they worth it? anyone tryed them?
back in a built sierra!
Post Posted: Sat Jul 14, 2012 1:01 pm
They aren't sleeves, they are dowels.
I'm not sure that warn hubs for sierras have dowels. And if they do, you'd still need to drill the holes in the hub for the dowels to locate.
But.... this could be done with OEM hubs too.
Vehicle: SJ80, SE416
Post Posted: Sat Jul 14, 2012 2:17 pm
Isn't the weak spot on CroMo Sierra CVs the groove cut in the short side next to the spline at the diff end, for this very reason? Then you replace the shaft - not the shafts and CV.
Also, if it was a Jeep Wrangler - they have uni-joints instead of CVs...
Post Posted: Sat Jul 14, 2012 2:54 pm
OEM hubs what are they?
and reubs it was a wrangler we know they dont have cvs....now i read what i wrote it does sould like we where sayin they did!haha
more just saying they break something easy instead of something internal!
Post Posted: Sat Jul 14, 2012 3:15 pm
OEM= Original Equipment Manufacturer i.e. standard hubs.
Post Posted: Sat Jul 14, 2012 3:35 pm
ah righto! how would wou put a dowel into a standard one?
Post Posted: Sun Jul 15, 2012 2:08 pm
Don't even bother thinking about it, just use it and if the bolts break put stronger ones in.
Post Posted: Sun Jul 15, 2012 2:15 pm
Hub fuses used to be available for Sierras,
but I never saw anyone using them.
They were dear, and had to save a lot of cv's to pay for themselves.
Changing a cv becomes easy with practise anyway :)
Vehicle: Coily.
Post Posted: Sun Jul 15, 2012 2:37 pm
OEM as already stated are supposed to be sourced from the original manufacturer but in reality can be just copies from our friendly Chinese factories.
Regards All from far Northern NSW.
Users browsing this forum: Google [Bot] and 328 guests
