It is currently Thu Oct 22, 2026 9:18 pm
Vehicle: suzuki sierra sj50
Post Posted: Fri Jul 27, 2012 1:05 pm
gday everyone my Sierra moves forward in neutral i have only noticed it when its cold it doesn't take off just slowly rocks forward in neutral and the revs change can anyone tell me what's wrong its a 1.3 g13a and its pretty much standard and it also vibrates in 4th/5th gear really bad i can feel it in the gear stick and throughout the whole car i can also hear it when on smooth surfaces :evil: :cry:
thanks
Vehicle: Yellow Ute
Post Posted: Fri Jul 27, 2012 2:40 pm
Pretty sure some other people have had their car move in neutral. So that may just be the oil is a bit old and thick, would be worse when its cold. viewtopic.php?f=5&t=8300&hilit=sierra+moves+in+nuetral
For the vibrations check your unis in the jackshaft and tail shaft have no play and go from there I guess.
Post Posted: Fri Jul 27, 2012 5:40 pm
i have checked the unis one of them has a tiny bit of play not alot and i have had worse on other cars and the vibration was not near as bad
Post Posted: Sat Jul 28, 2012 4:46 am
As above.....
Drain the gearbox oil. (TIP: undo the filler plug first.)
Remove the jackshaft and check the uni's.
Replace uni's if there is ANY play or stiffness in them.
Refit jackshaft.
Fill with new gearoil.
Post Posted: Sat Jul 28, 2012 1:08 pm
thanks i will check all these and let yous no how i go thanks
Users browsing this forum: Google Adsense [Bot] and 384 guests
