It is currently Tue Oct 20, 2026 7:19 am
Post Posted: Wed Aug 01, 2012 6:44 pm
hey all,
so ive got a 92 swb vitara 1.6l g16a manual
and i think its about time to get a re-con gearbox ,the one ive got makes all the weird noises especially in 5th gear
but i thought mabye putting an auto box into it? just wondering if anyone knows if ill have to change anything other than the box,gear stick and tranny cooler? Cheers :D
Post Posted: Wed Aug 01, 2012 8:04 pm
pretty sure the auto needs an ECU to control it also...
perhaps someone with a bit more knowledge than me can help...??? atari maybe???
Stocker
Vehicle: '96 LWB trayback
Post Posted: Wed Aug 01, 2012 8:31 pm
Carby vitara, whack in a 3spd auto. Call it a day.
Post Posted: Wed Aug 01, 2012 8:48 pm
cheers stocker yeah forgot about that
haha i wish it was that easy
Post Posted: Wed Aug 01, 2012 8:59 pm
Quote from another post "The 3 Speed (trimatic) is vacuum/thottle cable shifted No electronics" so maybe peddle box and vacuum lines to be changed and installed.
Post Posted: Wed Aug 01, 2012 9:06 pm
didnt know that thanks so would you know where the peddle box goes ? im asuming underneath the dash on top of the pedal arm or not?
do the vitaras come out with a 4speed auto?
and would anyone know what the auto 3speed is like in low range?
Post Posted: Wed Aug 01, 2012 9:10 pm
sorry what a stupid question of course they come out 4 speed haha :L
Post Posted: Wed Aug 01, 2012 9:11 pm
i think you can just remove the clutch peddle and change to a auto brake peddle and the box is above the steering shaft.
The 4 speed is for EFI only as it uses a computer which also sends a signal to the ECU.
Post Posted: Wed Aug 01, 2012 9:24 pm
cheers vits93
would anyone be able to post up pics of there gear box in your spare time? :D thanks
Post Posted: Wed Aug 01, 2012 10:55 pm
I have a low kms 4sp with T-bar, pedal box, TCM and TCM loom section for sale. The convertor comes with it, but You'll need a flex plate.
Post Posted: Thu Aug 02, 2012 3:44 am
Isnt the cross members different as well because the auto is longer or somethink
Post Posted: Thu Aug 02, 2012 6:06 pm
ill keep that in mind just gonna go to the wreckers first and go throught what i have to get and where everything is placed
thanks
mabye not sure
Post Posted: Thu Aug 02, 2012 6:09 pm
rear tailshafts are different on the 4 speed auto/manual... not sure about the 3 speed but i'd say they'll be different.
Vehicle: sierra
Post Posted: Thu Aug 02, 2012 6:18 pm
pretty good, the auto takes up the slack.
Post Posted: Thu Aug 02, 2012 6:33 pm
Auto has a bracket for the exhaust to bolt to other than that they are the same, but there is a support that bolts to the cross member and the chassis on the r/h side which the torque stopper Bush bolts to.
Users browsing this forum: No registered users and 432 guests
