It is currently Fri Sep 25, 2026 7:36 pm
Vehicle: SJ51T
Post Posted: Mon Aug 27, 2012 8:31 pm
What have you guys done to replace your factory scissor jack after fitting big wheels to your Sierras?
and I know a high lift jack is going to come up but I wanted an alternative
and exhaust jack has been thought of too so...
and Jack White.
and jumping jack
and....
ok, so this competition will be called a jack off.
go!
Post Posted: Mon Aug 27, 2012 8:37 pm
for my vitara i run a decent sized bottle jack that has a fairly long screw extension that comes out of the ram for extra height.
Vehicle: 2011 jimny
Post Posted: Mon Aug 27, 2012 8:46 pm
ive been thinking about upgrading to bottle jack as the standard scissor jacks are small and take ages to whine up and down
Post Posted: Mon Aug 27, 2012 8:59 pm
Take a block of wood.....or a brick
Vehicle: 03 Jimny
Post Posted: Mon Aug 27, 2012 9:01 pm
Toyota bottle jack
Post Posted: Mon Aug 27, 2012 9:05 pm
blocks of wood to use with standard jack
Post Posted: Mon Aug 27, 2012 9:10 pm
Mine has 2 blocks of wood.
Post Posted: Mon Aug 27, 2012 9:11 pm
3 for me :lol:
Vehicle: Clown Car..
Post Posted: Mon Aug 27, 2012 10:52 pm
My woods packed...
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Tue Aug 28, 2012 5:24 am
Pajero bottle jack, 2 shafts one inside the other + screw.
More compact that the sissor jack, yet > 50% higher.
Post Posted: Tue Aug 28, 2012 5:54 am
I had used my exhaust jack once in three years, pulled it out a month ago to have a play on the cement, and the seam had come apart.Binned it.I think it was a Bushranger.
bye
Post Posted: Tue Aug 28, 2012 7:00 am
I used to put one of my ammo boxes under the stock jack, but I've just welded some 100x 50 rhs to the foot and some 50x50 to the top. Plenty tall enough now.
Post Posted: Tue Aug 28, 2012 7:16 am
Don't use a hi lift to change a tyre. Bottle jacks are cheap as and work fine
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Tue Aug 28, 2012 10:29 am
Don't use a brick... They can shatter!
Vehicle: '94 suzuki maruti
Post Posted: Tue Aug 28, 2012 5:16 pm
i just bought one of those hydraulic workshop jacks, cart a cheap one of those around with me. although, i have a toolbox on the tray, so its not an option for everyone...
Post Posted: Tue Aug 28, 2012 5:27 pm
you must have room to burn carting around a trolley jack & the pissy standard scissor jack is a joke.
this is what i run, will still fit under the diff tube if i've got a complete flat & has heaps of travel.
Post Posted: Tue Aug 28, 2012 6:06 pm
Shep why wouldn't ya use a hi-lift jack to change a tyre.
We put some shit under the car whilst it's up anyway.
bye
Vehicle: 1985 lwb sierra UTE
Post Posted: Tue Aug 28, 2012 6:38 pm
Ii was thinking about making a braket to hold a trolley jack under the bonnet on the left instead of on the right or custome the original ,unless any 1 can think of a negative to the idea, if not I might get a yota bottle jack
Post Posted: Tue Aug 28, 2012 6:44 pm
bye
There aren't many cars on the market that you can uses a hi-lift jack on with out either damaging the vehicle or it being unsafe. IMO they belong on the farm doing stuff like pulling star pickets etc.
Sven
Post Posted: Tue Aug 28, 2012 6:47 pm
Some how I missed Attari4x4 post befor i posted.I might just get one of those
Post Posted: Tue Aug 28, 2012 6:51 pm
bye
Hi :hey:
Using a Hi lift to change a tyre is awesome if you strap the axle to the chassis before you lift the car, then, you only have to lift the body of the car the height of the sidewall of the tyre to get the tyre off.
If you don't do this, you have to lift the car the height of the sidewall of the tyre, + the droop in your suspension. that puts the body of the car higher than necessary, and makes everything very spooky.
I can't impress on everyone enough the MASSIVE improvement in safety when using a hi lift with the axle strapped to the chassis.
However, its all a lot of stuffing around (and extra weight) to end up with something no better than a standard jack with a block welded onto it. Of course, a stock jack with a block welded to it doesn't look as cool on top of your bullbar though.
bye
Post Posted: Tue Aug 28, 2012 7:12 pm
Thanks Steve good point did u make it look standard or no need
Vehicle: SJ51T
Post Posted: Tue Aug 28, 2012 7:37 pm
If I get a flat I'm heading for your jack this weekend Steve,
I'll take a look at it puncture or no puncture anyways.
thanks for the replies everyone.
Post Posted: Tue Aug 28, 2012 7:42 pm
? Not sure what you mean - I've just welded some 100X50mm RHS to the bottom and 50X50 to the top. It doesn't look anything like standard :D
Post Posted: Tue Aug 28, 2012 8:02 pm
We use them to change tyres but there are mounts for the jack built into each corner of the car so the car can't fall over.
Still not a ideal way of changing tyres but with a few people helping it takes less then a minute to change a tyre and we get a crap load of flat tyres.
Post Posted: Wed Aug 29, 2012 3:26 am
U know trimed the shape so it looked factory ( not sure how in this case ) he. He don't worry I will probably be doing the exact same know lol
Users browsing this forum: No registered users and 130 guests
