| Author |
Message |
jonfromhamilton
Joined: Mon Dec 26, 2011 2:11 pm Posts: 410 Location: Pakenham
Vehicle: SJ51T
 Posted: Mon Aug 27, 2012 8:31 pm |
What have you guys done to replace your factory scissor jack after fitting big wheels to your Sierras?
and I know a high lift jack is going to come up but I wanted an alternative
and exhaust jack has been thought of too so...
and Jack White.
and jumping jack
and....
ok, so this competition will be called a jack off.
go!
atari4x4
 Posted: Mon Aug 27, 2012 8:37 pm |
for my vitara i run a decent sized bottle jack that has a fairly long screw extension that comes out of the ram for extra height.
kristov
Joined: Wed Oct 12, 2011 8:47 pm Posts: 347 Location: Bunbury, WA
Vehicle: 2011 jimny
 Posted: Mon Aug 27, 2012 8:46 pm |
ive been thinking about upgrading to bottle jack as the standard scissor jacks are small and take ages to whine up and down
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Mon Aug 27, 2012 8:59 pm |
Take a block of wood.....or a brick
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Mon Aug 27, 2012 9:01 pm |
Toyota bottle jack
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Mon Aug 27, 2012 9:05 pm |
blocks of wood to use with standard jack
christover1
 Posted: Mon Aug 27, 2012 9:10 pm |
Mine has 2 blocks of wood.
appsie
 Posted: Mon Aug 27, 2012 9:11 pm |
3 for me
foolsp33d
Joined: Tue Mar 11, 2008 10:30 pm Posts: 2123 Location: Deep Inside Jamies Mouth
Vehicle: Clown Car..
 Posted: Mon Aug 27, 2012 10:52 pm |
neofitou
Joined: Wed Mar 24, 2010 10:30 pm Posts: 1088 Location: Melbourne
Vehicle: 00 Jimny, 63 Haffy
 Posted: Tue Aug 28, 2012 5:24 am |
Pajero bottle jack, 2 shafts one inside the other + screw. More compact that the sissor jack, yet > 50% higher.
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Tue Aug 28, 2012 5:54 am |
I had used my exhaust jack once in three years, pulled it out a month ago to have a play on the cement, and the seam had come apart.Binned it.I think it was a Bushranger.
bye
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Tue Aug 28, 2012 7:00 am |
I used to put one of my ammo boxes under the stock jack, but I've just welded some 100x 50 rhs to the foot and some 50x50 to the top. Plenty tall enough now.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Aug 28, 2012 7:16 am |
Don't use a hi lift to change a tyre. Bottle jacks are cheap as and work fine
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
fritter
Joined: Sun Sep 19, 2010 9:30 am Posts: 1163 Location: Wahroonga NSW
Vehicle: 89 Vit. The Desert Rat...
 Posted: Tue Aug 28, 2012 10:29 am |
Don't use a brick... They can shatter!
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Tue Aug 28, 2012 5:16 pm |
i just bought one of those hydraulic workshop jacks, cart a cheap one of those around with me. although, i have a toolbox on the tray, so its not an option for everyone...
atari4x4
 Posted: Tue Aug 28, 2012 5:27 pm |
you must have room to burn carting around a trolley jack & the pissy standard scissor jack is a joke. this is what i run, will still fit under the diff tube if i've got a complete flat & has heaps of travel.
cairns27
 Posted: Tue Aug 28, 2012 6:06 pm |
Shep why wouldn't ya use a hi-lift jack to change a tyre.
We put some shit under the car whilst it's up anyway.
bye
KEENSY85
Joined: Wed May 09, 2012 12:46 am Posts: 1742 Location: north brisbane
Vehicle: 1985 lwb sierra UTE
 Posted: Tue Aug 28, 2012 6:38 pm |
fritter wrote: Don't use a brick... They can shatter! Ii was thinking about making a braket to hold a trolley jack under the bonnet on the left instead of on the right or custome the original ,unless any 1 can think of a negative to the idea, if not I might get a yota bottle jack
atari4x4
 Posted: Tue Aug 28, 2012 6:44 pm |
cairns27 wrote: Shep why wouldn't ya use a hi-lift jack to change a tyre.
bye There aren't many cars on the market that you can uses a hi-lift jack on with out either damaging the vehicle or it being unsafe. IMO they belong on the farm doing stuff like pulling star pickets etc. Cheers Sven
KEENSY85
 Posted: Tue Aug 28, 2012 6:47 pm |
Some how I missed Attari4x4 post befor i posted.I might just get one of those
Gwagensteve
 Posted: Tue Aug 28, 2012 6:51 pm |
bye Hi Using a Hi lift to change a tyre is awesome if you strap the axle to the chassis before you lift the car, then, you only have to lift the body of the car the height of the sidewall of the tyre to get the tyre off. If you don't do this, you have to lift the car the height of the sidewall of the tyre, + the droop in your suspension. that puts the body of the car higher than necessary, and makes everything very spooky. I can't impress on everyone enough the MASSIVE improvement in safety when using a hi lift with the axle strapped to the chassis. However, its all a lot of stuffing around (and extra weight) to end up with something no better than a standard jack with a block welded onto it. Of course, a stock jack with a block welded to it doesn't look as cool on top of your bullbar though. bye
KEENSY85
 Posted: Tue Aug 28, 2012 7:12 pm |
Thanks Steve good point did u make it look standard or no need
jonfromhamilton
Vehicle: SJ51T
 Posted: Tue Aug 28, 2012 7:37 pm |
If I get a flat I'm heading for your jack this weekend Steve, I'll take a look at it puncture or no puncture anyways.
thanks for the replies everyone.
Gwagensteve
 Posted: Tue Aug 28, 2012 7:42 pm |
KEENSY85 wrote: Thanks Steve good point did u make it look standard or no need ? Not sure what you mean - I've just welded some 100X50mm RHS to the bottom and 50X50 to the top. It doesn't look anything like standard  Steve.
shep
 Posted: Tue Aug 28, 2012 8:02 pm |
We use them to change tyres but there are mounts for the jack built into each corner of the car so the car can't fall over. Still not a ideal way of changing tyres but with a few people helping it takes less then a minute to change a tyre and we get a crap load of flat tyres.
KEENSY85
 Posted: Wed Aug 29, 2012 3:26 am |
Gwagensteve wrote: KEENSY85 wrote: Thanks Steve good point did u make it look standard or no need ? Not sure what you mean - I've just welded some 100X50mm RHS to the bottom and 50X50 to the top. It doesn't look anything like standard  Steve. U know trimed the shape so it looked factory ( not sure how in this case ) he. He don't worry I will probably be doing the exact same know lol
