It is currently Sun Oct 18, 2026 1:13 pm
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Mon Oct 01, 2012 6:35 am
Hi guys I have tail jimny 24% reduction fitted and jimny bits transfer mount kit, 2" body lift. I have enlargened the shifter hole in the body as it fouls with body lift in, but when car is under a lot of load it jumps out of 4wl into kind of a neutral/grinding between 4wl and 4wh. Any thoughts? Help?
Post Posted: Mon Oct 01, 2012 6:41 am
Is it a ratcheting kind of sound? Perhaps it is the chain slipping.
Post Posted: Mon Oct 01, 2012 10:06 am
Nope definitely a popping and disengage noise, put it back in 4wl and fine.
Post Posted: Mon Oct 01, 2012 10:32 am
I totally still think it torques over and knocks itself out of gear, it only did it when you were approaching full noise...
Post Posted: Mon Oct 01, 2012 6:23 pm
You reckon if I enlarge transfer shifter hole a bit and try different mounts it may cure it Josh?
Post Posted: Mon Oct 01, 2012 6:37 pm
stiffer mounts
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Oct 01, 2012 7:23 pm
Aren't you already running the ORA mounts Daz?
Users browsing this forum: No registered users and 257 guests
