| Author |
Message |
Ballbag
Vehicle: 1996 Suzuki Sierra Soft Top
 Posted: Mon Oct 01, 2012 9:36 pm |
Hi guys. Firstly I have a 1996 soft top Sierra. I have recently noticed an oil drip from the face of the Bel housing and rear of the sump cover. I've wiped a bit off, but as you see in the photos that is the region where the leak is coming from? Also a bit of oil from the gap looking thing at the bottom of the case? Please enlightened me of what this is? As you can see i am by no means a mechanic, so any Ideas of what seal/gasket this might be and what would be required to repair. Thanks
djed
Joined: Wed Jan 05, 2011 7:31 am Posts: 114 Location: oz
 Posted: Mon Oct 01, 2012 10:17 pm |
sump gasket or rear main seal
shandy92
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
 Posted: Mon Oct 01, 2012 11:35 pm |
have a look down the back of the motor, if is wet up there as well then it could be the distributor o-ring or rocker cover gasket. start with the highest seal and work down. if its completely dry all the way down, then yes it could be the rear main crankshaft seal or sump gasket.
DarkHorse
 Posted: Mon Oct 01, 2012 11:42 pm |
FYI - put the image address in [img]***[/img] tags and they'll come up in your post. They can be copied straight from Photobucket too, they'll be in the "IMG" box.
Ballbag
 Posted: Mon Oct 01, 2012 11:49 pm |
Its not the Distributor O-ring or rocker cover gasket as i replaced them both recently and stopped their leaks. The engine is oil free downward until you reach the area depicted.
Ballbag
 Posted: Mon Oct 01, 2012 11:50 pm |
shandy92 wrote: have a look down the back of the motor, if is wet up there as well then it could be the distributor o-ring or rocker cover gasket. start with the highest seal and work down. if its completely dry all the way down, then yes it could be the rear main crankshaft seal or sump gasket. And thanks for the responses so far!
DarkHorse
 Posted: Mon Oct 01, 2012 11:52 pm |
There ya go  It's coming from above the sump, so that's fine. Check all your bellhousing bolts, one could be loose and allowing some seepage. If they're all tight and you can pinpoint the start it could be a rear main.
hooki
Joined: Mon Jul 21, 2008 11:30 pm Posts: 1785 Location: perth, WA
 Posted: Tue Oct 02, 2012 1:39 am |
+1 vote for the rear main.
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2659 Location: Georgetown, Guyana
 Posted: Tue Oct 02, 2012 4:09 am |
DarkHorse wrote: Check all your bellhousing bolts, one could be loose and allowing some seepage. Where would that oil be seeping from? If it's not coming from above the bellhousing (dist O ring, valve cover, head gasket), I think you're down to the rear main or the oil pan.
