It is currently Sat Oct 17, 2026 5:39 am
Vehicle: 1996 Suzuki Sierra Soft Top
Post Posted: Mon Oct 01, 2012 9:36 pm
Hi guys.
Firstly I have a 1996 soft top Sierra.
I have recently noticed an oil drip from the face of the Bel housing and rear of the sump cover.
I've wiped a bit off, but as you see in the photos that is the region where the leak is coming from?
Also a bit of oil from the gap looking thing at the bottom of the case? Please enlightened me of what this is?
As you can see i am by no means a mechanic, so any Ideas of what seal/gasket this might be and what would be required to repair.
Thanks
Post Posted: Mon Oct 01, 2012 10:17 pm
sump gasket or rear main seal
Post Posted: Mon Oct 01, 2012 11:35 pm
have a look down the back of the motor, if is wet up there as well then it could be the distributor o-ring or rocker cover gasket. start with the highest seal and work down. if its completely dry all the way down, then yes it could be the rear main crankshaft seal or sump gasket.
Post Posted: Mon Oct 01, 2012 11:42 pm
FYI - put the image address in [img]***[/img] tags and they'll come up in your post. They can be copied straight from Photobucket too, they'll be in the "IMG" box.
Post Posted: Mon Oct 01, 2012 11:49 pm
Its not the Distributor O-ring or rocker cover gasket as i replaced them both recently and stopped their leaks. The engine is oil free downward until you reach the area depicted.
Post Posted: Mon Oct 01, 2012 11:50 pm
And thanks for the responses so far!
Post Posted: Mon Oct 01, 2012 11:52 pm
There ya go ;)
It's coming from above the sump, so that's fine. Check all your bellhousing bolts, one could be loose and allowing some seepage. If they're all tight and you can pinpoint the start it could be a rear main.
Post Posted: Tue Oct 02, 2012 1:39 am
+1 vote for the rear main.
Post Posted: Tue Oct 02, 2012 4:09 am
Where would that oil be seeping from?
If it's not coming from above the bellhousing (dist O ring, valve cover, head gasket), I think you're down to the rear main or the oil pan.
Users browsing this forum: No registered users and 234 guests
