It is currently Sat Sep 19, 2026 4:48 am
Post Posted: Thu Nov 08, 2012 4:04 pm
hey guys my sills are pretty smashed up on my jimny and just touching the door now. i was wondering has anyone done a sill chop on a jimny then replaced it with some rhs then bolted it to the chassie if so could you post some pics up
im looking for something like this but for a jimny viewtopic.php?f=5&t=29476&hilit=sill+chop
Post Posted: Thu Nov 08, 2012 8:24 pm
I'm pretty sure nobody on here has done a sill chop on a Jimny yet.
I have done a repair to a fairly damaged Jimny sill and I don't think it would be any harder that on a Sierra. If you are going to reinforce the sill with RHS you shouldn't also attach to the chassis as the body and chassis aren't hard fixed.
Post Posted: Fri Nov 09, 2012 9:54 am
If there hollow in there there isn't a difference, but if its got supports or weird ribbing it could throw the whole operation out. I plan on notching mine so I can run the chassis mounted supports up as high as possible...
Post Posted: Fri Nov 09, 2012 10:30 am
When I had the black Jimny sill open for repair I don't remember seeing anything, pretty sure they are hollow
Vehicle: 2003 Jimny Auto
Post Posted: Fri Nov 09, 2012 6:51 pm
The chassis is way lower than the sills, but I was gonna do some body mounted sliders for mine still. The chassis can take a knock here and there and the angles usually punish your sills first. One of my plastic ones got ripped right off!
I couldnt figure out the best way to do it but I reckon RHS is the go. Bolt on? But to the body, not the chassis.
Post Posted: Fri Nov 09, 2012 7:07 pm
I wish I saved some pictures of the silver jimny when I was looking at buying my jimny. There is a silver jimny getting around the Sunshine Coast, he replaced his sills with about a three inch tube but it looks really neat, the jimny has had the grill cut off the bonnet and replaced it with some toy boy racer mesh.
Last edited by dougies_tx5turbo on Fri Nov 09, 2012 8:54 pm, edited 1 time in total.
Post Posted: Fri Nov 09, 2012 7:11 pm
And I will maybe be doing something like this in a couple of years when the car will be getting used more http://www.fts4x4.com/en/products/?meth ... il&aid=666
Edit here is some more on auszooker viewtopic.php?f=14&t=9178
Another http://forum.difflock.com/viewtopic.php ... 0edb6db0f3
Post Posted: Fri Nov 09, 2012 10:53 pm
dougies_tx5turbo wrote:
Edit here is some more on auszooker http://www.auszookers.com/forum/viewtop ... =14&t=9178
And I still have the steel sitting in the shed :oops: :roll:
Vehicle: 03 Jimny
Post Posted: Sat Nov 10, 2012 8:12 am
They have a radius body panel under the plastic sill covers.
Just cut it out(its hollow) and put some rhs in there.
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Nov 10, 2012 11:42 am
Does/did yours have plastic moulds on the doors?
Vehicle: 03 Jimny
Post Posted: Sat Nov 10, 2012 12:04 pm
Still does
Post Posted: Sat Nov 10, 2012 12:23 pm
Do they stick out far past the sills?
Post Posted: Sun Nov 11, 2012 7:28 am
Obviously not a Jimny, but it is an idea that you may consider.
Is fitted on to body panels with riv nuts
Post Posted: Wed Nov 14, 2012 12:54 am
thanks for the help guys tx5turbo one of the links you posted has a goldidh jimny i like the look of the sliders on that when i get around to it i might try and make something like that
Users browsing this forum: Google [Bot] and 134 guests
