It is currently Sun Sep 27, 2026 1:44 pm
Post Posted: Tue Nov 20, 2012 6:11 pm
Hey all I rebuilt my motor on the weekend!!! Is awsome untill the auto choke turns off! Haha has a vacuume leak somewhere... If I cover half the carby the engine idels like a gem!!!
On the weekend I am going to rip the carby and inlet manifold off again and new gaskets and make sure it's all sealed up properly.
Is there anywhere I should be looking that is common on a 1.3?
Also the gasket kit I got is for a g13a... Mines a g13b... Are the inlet manifolds different?
Post Posted: Tue Nov 20, 2012 6:18 pm
No, all gaskets should be the same assuming you are talking SOHC G13B, get some startyabastard or similar and spray around carby/intake, if revs pick up you have found your leak.
Post Posted: Tue Nov 20, 2012 7:03 pm
the vacuum actuators can seize/leak, also
Post Posted: Wed Nov 21, 2012 6:36 pm
cheers guys i will check this before i pull it apart again....i got new gaskets today....
Users browsing this forum: Google [Bot] and 65 guests
