It is currently Sun Aug 02, 2026 10:01 am
Vehicle: Red 1988 Suzuki Sierra
Post Posted: Thu Nov 29, 2012 10:35 am
Hi guys, just a quick one, I've recently put in a 2in spring lift, and installed longer shocks (blue max) but the ride was absolutely SHOCKING! I took a leaf out of all the packs (a little better, but still spine breaking) and a few days later , installed the standard rear shocks, this made it monumentally better to drive on road, but these are at near on full travel when flexed..
Are the commodore shocks approximately the same rate as std sierra ones, or will I run into the same problems as I'm encountering now?
Any help would be appreciated!
Kaya.
Vehicle: 1987 Suzuki Sierra hard top
Post Posted: Thu Nov 29, 2012 11:21 am
Kayarubin,
Did you mean Blue pack?? off Ebay???
I was gonna buy these for mine Damn.
Vehicle: Vit swb 95
Post Posted: Thu Nov 29, 2012 11:35 am
Check your tyre preasures?
Post Posted: Thu Nov 29, 2012 5:37 pm
No it's a not so well known company called blue max, they're not as cheap as blupac, (probably halfway between them and OME quality) but the shocks are just plain fu#*ed ride quality wise.. I imagine blupac wouldn't be much better, but considering their price, I'd still consider them (maybe take a leaf out like I did to soften them up a bit.)
I have changed the pressures ranging from 15psi, right up to 35, and everything in between, to no avail. I'm happy to use std shocks for now, but once i get a little more height out of it, I'd like to change them to extended type.
Kaya.
Vehicle: SJ80, SE416
Post Posted: Thu Nov 29, 2012 6:09 pm
Seriously no difference felt? Try 22 or less - no higher EVER...
Post Posted: Thu Nov 29, 2012 6:13 pm
must be driving on morphine 8O
Vehicle: 4wd
Post Posted: Thu Nov 29, 2012 6:18 pm
The problem is not so much the shocks, but the cheap and nasty springs.
Watch out or you'll get sued.
Post Posted: Thu Nov 29, 2012 6:31 pm
The problem stockman, is that you can't read :thefinger:
Kayarubin for a budget shock I've used Boge turbo shocks. They seem to be fairly softly valved with descent travel. I'm running koni 80 series rebound adjustable shocks which are a bit more pricey but have been the best shocks I've had under any leafy so far.
Vehicle: 4wd
Post Posted: Thu Nov 29, 2012 6:37 pm
You can't read either :kissmyarse:
Post Posted: Thu Nov 29, 2012 7:35 pm
^Blue Suzy is free Armsup
When I ran the commo/lux combo (like everyone says) there valves a bit stiff for a Sierra, but are very reasonable.
I also think its due to the leaf springs also. I run commo shocks on the front of my jimny, and the valving is spot on!
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Nov 30, 2012 4:06 am
U could try doetch from lror
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Fri Nov 30, 2012 9:58 pm
I've got the same problem in my sierra. Very harsh ride with leaf springs and Rancho 5000 shocks. I think the brand of springs is 'rock crawler'. They were purchased and installed by the previous owner at 4wd1 shop
Post Posted: Sat Dec 01, 2012 12:53 am
Sounds like the eBay kit you can get
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Vehicle: 95 Sierra Soft top
Post Posted: Sat Dec 01, 2012 10:00 am
There nothing great, i got the doetch 3000 and there still pretty ruff but again im running a diffrenet springs
Post Posted: Sat Dec 01, 2012 5:01 pm
Dont you have 3" springs?
Post Posted: Sat Dec 01, 2012 7:04 pm
3'' what brand?
Post Posted: Sat Dec 01, 2012 8:45 pm
Yes i am running the lror 3" springs but i recently picked up my sierra from the shop and pretty happy what they did to the springs to make them flex,
They pulled a leaf out from each pack and heated them then recorved them so im a touch higher then 3" but flexs very good, but still a pretty bumby ride, but they are brand new springs so they will soften up abit, but after time i will like to try diffrenet shocks see whats softer and comfier
Vehicle: 4wd
Post Posted: Sat Dec 01, 2012 8:50 pm
KEENSY85 wrote:
3'' what brand?
Calmini do a 3" spring and there also very stiff.
Post Posted: Sat Dec 01, 2012 9:43 pm
I thought shep at a set don't they use the boomerang shackels to get the extra lift?
Vehicle: 4wd
Post Posted: Sat Dec 01, 2012 9:52 pm
3" springs
reverse shackle brings it to 5" lift
Vehicle: '94 suzuki maruti
Post Posted: Sat Dec 01, 2012 9:59 pm
don't use rancho's... i run the adjustable (9000) in my maruti and on the softest setting the rear was ok-ish but the front is still waaay too firm.
Post Posted: Sun Dec 02, 2012 6:07 am
My next will be Koni most likely, I just had some weird lengths to match and when I rang Koni shocks they weren't very helpful. And doetch shocks were still 300 cheaper
Post Posted: Sun Dec 02, 2012 6:31 am
stockman wrote:
3" springs
4" rear and they are to soft on a lwb, can invert stock shackles driving up a gutter. Flex like a slinky but.
Users browsing this forum: No registered users and 67 guests
