It is currently Sun Aug 02, 2026 12:31 pm
Vehicle: 89 Softtop Sierra, 6.5's, 30's
Post Posted: Sat Nov 06, 2010 8:24 am
I've tried using the chisel and hammer method, and also the bashing it and swearing method, both to no avail.
Would heating it up be worthwhile? Or is drilling it out my only option? I can't weld something onto it right at the moment, otherwise I'd try that.
Any help would be appreciated.
Sam
Oh and its starting to round.
Post Posted: Sat Nov 06, 2010 8:31 am
freeze your nuts off, is the go :D or, just get a clever man to weld a M20 bolt to it and it will never be an issue again :) then once it's off go down to your local bolt shop buy a massive headed plug and you will be fine :)
Post Posted: Sat Nov 06, 2010 8:36 am
Yeah if I had a welder at home I'd have done that by now. If welding isn't an option is it just down to drilling it out then?
Post Posted: Sat Nov 06, 2010 8:54 am
Grind it so it's shaped like a rectangle
Then get the vice grips onto it? With a reallllly big extension bar haha
Post Posted: Sat Nov 06, 2010 9:07 am
when you put it back in put copper anti seize gease on the thead or teflon tape works well too. they never stick then.
Post Posted: Sat Nov 06, 2010 9:10 am
you can get an impact driver.
its a 3/8 drive fits perfectly into the hole.
all you do is hold it in the hole and hit it with a hammer.
the force of the hammer hitting it gives it a shock and turns the bolt loose.
any good tool shop will have 1.
and if you ask them to show you how to use it then you will be right.
Kyle
dodgy brothers mechanical
Post Posted: Sat Nov 06, 2010 9:23 am
Sikaflex does the same job too .
Post Posted: Sat Nov 06, 2010 9:25 am
Kyle
Using 3/8 drives in there is what rounds them out in the first place....
I want my old sig back :(
Post Posted: Sat Nov 06, 2010 10:20 am
3/8th does not equal 10mm.
Post Posted: Sat Nov 06, 2010 10:22 am
Indeed it doesn't. It equals 9.525mm
Post Posted: Sat Nov 06, 2010 12:25 pm
x2 awesome stuff
lost in suzuki space
Post Posted: Sat Nov 06, 2010 10:20 pm
but. the impact socket works a treat.
didn round the hole on mine but got it loose for shore
Post Posted: Sun Nov 07, 2010 3:21 am
ohhh and you were so close to finishing your massive service haha. I reckon get an impact drive and give that a go first before you go welding a new creation
Post Posted: Sun Nov 07, 2010 3:33 am
impact driver or even rattle gun are the go cause it shocks it and isnt putting a side load on like a breaker bar will
Post Posted: Sun Nov 07, 2010 4:49 am
Surely there is an actual tool for this? Like suzuki made?
Went to Bunnings to get a 10mm driver and was told they have nothing like it. 3/8 was suggested.
Note to self: In future always check the filler hole is able to screw out before emptying diff oil
Post Posted: Sun Nov 07, 2010 4:56 am
yeah funny enough its called a filler plug removal tool, available at your local friendly carp shop, at elast it was last time we have one of theae threads a few weeks ago
Post Posted: Sun Nov 07, 2010 5:07 am
Usually I search first. My apologies, got frustrated and wanted a quick answer.
Thanks for your responses.
Sam
Post Posted: Mon Feb 11, 2013 12:16 pm
Can anyone tell me where to buy a 10mm key driver for the diff bolts??
I've googled it a fair bit and come up with nothing..
Post Posted: Mon Feb 11, 2013 12:27 pm
mine came from ebay http://www.ebay.com.au/itm/CTA-2049-2-P ... 2c6b52809a
Post Posted: Mon Feb 11, 2013 2:13 pm
Thanks Atari!! I must have searched the wrong words on eBay..
Cheap enough to buy the tool but goodness the postage is heafty :-/
Vehicle: 85 ' Drover
Post Posted: Mon Feb 11, 2013 2:25 pm
I have filled a differential with oil via the axel hole once because i couldnt get the filler plug open.
downside is you need to know exactly how much to put in, and you need to pull appart the axel stuff as well.
But hey it works.
Vehicle: SWB Sierra
Post Posted: Mon Feb 11, 2013 2:29 pm
Jeez, wouldn't it be easier to fill through the breather with a than pull an axle?
Vehicle: 86 SJ413 dings / rust / 30's
once it starts to round stop!!! file flat and rethink what your doing. 12pt socket ok - 6pt socket better, open end spanner less likely to round the hex.
Can you get hold of an manual impact driver (the ones you hit and they undo/do up) and possibly cut a deep slot with a 1 or 2mm cutoff wheel? also tap it with a 4lb hammer, dont fk round give it a good tap.
Post Posted: Mon Feb 11, 2013 2:34 pm
Not sure, probably:P
I was playing with the axels that day anyway (new axel bearings), so i had them half appart when i realised i coudlnt undo the filler.
Post Posted: Mon Feb 11, 2013 2:55 pm
I reckon they are going to round out the plug almost as badly as a 3/8 drive.
Notice how they don't have a flat end, they're domed? this is what causes them to start to back out IMHO. If you use these, grind the end flush so they fully engage with the plug.
Vehicle: 4wd
Post Posted: Mon Feb 11, 2013 3:08 pm
I got mine from TCOR Armsup
Watch out or you'll get sued.
Post Posted: Mon Feb 11, 2013 5:34 pm
Thanks Steve..
What/where/who is TCOR?
Not keen of filling through the breather or axle housing... At some point I'm going to want to check the oil level and replace it periodically.. I'd rather just get it budged.. I already have a replacement plug (but still same stupid ass square drive).
I will probably look at getting an impact driver Ace.. The rear one was already well rounded before I got to it so had to ld a nut onto it.. That was a few hours of my life I'd rather forget.. Hoping to do a cleaner job of the front!!
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Tue Feb 12, 2013 9:43 am
This is the one I got:
http://www.ebay.com.au/itm/CTA-2497-8-i ... 2c5ede30c2
$23 including delivery and is properly square. I bought a few tools from that guy, my aircon servicing stuff mostly.
Unfortunatly I didnt buy it for my sierra, I already had hex sockets. but now I have one tool with both.
Post Posted: Tue Feb 12, 2013 9:46 am
Ha! Ignore that last post of mine!
It was $26 with free shipping when I bought it. now he wants $26 for the tool and $26 for the shipping!!
I double checked in my ebay history. wow, he must have got burned.
Users browsing this forum: No registered users and 52 guests
