It is currently Sun Oct 18, 2026 10:48 pm
Post Posted: Wed Jun 29, 2011 6:00 am
I have seem to remember mention of changing the wiring on the airlocker switches to be able to activate the front locker independent of the rear?
I have followed the standard wiring diagram and the front locker will not activate until the rear is also switched on. I have the little compressor so its the 'CKA12 12 volt' diagram.
Is anyone able to tell me what to switch or change to make them independent?
Post Posted: Wed Jun 29, 2011 6:18 am
Unplug yellow from switch 2, make a new wire to plug into the spot where yellow was and tap it into teh red wire on switch one
something like this?
Post Posted: Wed Jun 29, 2011 6:19 am
i win, mine has pics :wink:
Post Posted: Wed Jun 29, 2011 6:33 am
Thanks! :P
Post Posted: Wed Jun 29, 2011 6:44 am
I win, I knew how to do it, not how to google it
Post Posted: Wed Jun 29, 2011 7:33 am
I also wanted to know this
Thanks for asking the question tmb99 :helloo:
Post Posted: Wed Jun 29, 2011 8:09 am
I never saw any real benefit in doing this unless your car was setup for front dig....
Post Posted: Wed Feb 20, 2013 11:04 pm
bit of a bump... i'll probably do this "just cos" - but has anyone had the NEED for front only with an open rear??? I can't think of when it would be an advantage to lock the front and unlock the back???
Post Posted: Thu Feb 21, 2013 6:09 am
fronts against a big ledge, rears on a side slope, fronts will pull you up the ledge, keeping the rear open will mean one tyre isnt spinning so will hold against teh slope a bit better
Post Posted: Thu Feb 21, 2013 8:01 am
Or rear is hooked up well and trying to drive under you.
Just wire the red wire from the rear locker up to the yellow wire on the front switch.
Users browsing this forum: Google [Bot] and 212 guests
