It is currently Tue Oct 20, 2026 9:45 am
Vehicle: Suzuki Vitara JLX 1991
Post Posted: Fri Feb 22, 2013 3:06 pm
Hi Folks,
I have a weeping Trans drain bolt. I have tried the thread tape and it hasnt worked. Slowly dripping trans oil.
IS there anyway to counter the problems. Seems the transfer case and diffs have no issue but the trans just wont stop weeeping oil.
Any fixes?
Post Posted: Fri Feb 22, 2013 3:59 pm
Has it got the seal on it still? I'd replace it with a new ?copper seal.
Post Posted: Fri Feb 22, 2013 4:58 pm
Nah mate no seal. Can i get one for supercheap auto?
Post Posted: Fri Feb 22, 2013 5:05 pm
I am also not sure if the 1991 vitara are supposed to have a seal because there is no taper for the seal to ride up against to hold it in place. hmmmm 8-O
Post Posted: Fri Feb 22, 2013 5:14 pm
degrease & clean up the drain plug so it's spotless, run a small bead of oil friendly silicone around the flange & let it tack off so it's almost dry, then fit.
Post Posted: Sat Feb 23, 2013 2:25 am
If there's a flange there should be either a copper or plastic washer to seal it - if there is no flange, it will be tapered and thread seal should work.
Post Posted: Sat Feb 23, 2013 5:22 am
You only have to worry when it stops leaking.
Post Posted: Sat Feb 23, 2013 6:43 am
Mine was weeping. Didn't bother fixing till fluid change was due.
I retapped mine and fitted a slightly bigger drain plug., but my thread was stuffed.
Changing pan could be a better solution.
Mine still weeps slightly, but hasn't shown any drop on stick,
or dripped on the skid pan yet.
Users browsing this forum: Google Adsense [Bot] and 236 guests
