Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Sun Mar 03, 2013 2:41 pm |
Ive have just done a head gasket swap on my baleno g16b, having some issues getting it running and wondering if I have the cam pulley set up right. Pulley has two marks, E and I. I lined the pin on the end of the cam up with the slot on E, and then used E to line up to the the mark on the rocker cover. Is this the correct way?
royce
 Posted: Sun Mar 03, 2013 2:48 pm |
Its E on a 16v Vitara so ill assume yes
boostedbrick
Vehicle: 2018 DMAX
 Posted: Sun Mar 03, 2013 3:02 pm |
Ok, that's good. Problem is elsewhere.
PORL
Joined: Fri Sep 17, 2010 8:42 am Posts: 262 Location: Beeliar WA
Vehicle: 2004 Jimny 1.6
 Posted: Sun Mar 03, 2013 4:28 pm |
It's the E 100% what is the engine issue? Was the cam removed by any chance?
boostedbrick
Vehicle: 2018 DMAX
 Posted: Sun Mar 03, 2013 5:49 pm |
Cam needed to be removed to get the head bolts out.
I have spark and fuel. Turns over fine but struggles to fire, it sounds like a timing issue to me when it turns over, but I have tried the dizzy in every conceivable position. This is what made me wonder about the cam pulley.
I need to find the check engine light wire (bloody dash out job) and see if any codes come up.
PORL
 Posted: Sun Mar 03, 2013 11:01 pm |
Just a quick one. I had a similar issue. Check all your rocker arms and make sure they are located correctly over the valves. They have a nasty tendency of not sitting directly on top of the valve head. Just a thought. And it's a quick check
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 103 guests
