It is currently Tue Oct 27, 2026 8:23 pm
Post Posted: Sun Apr 07, 2013 6:03 pm
Hi All
OK, I want to put rear disks on my LJ80 before it goes back together. So in all the existing rear disc brake threads people will mention a brake proportioning valve to correct proportioning. But my question is, who can I buy one from in Australia? And if someone can suggest a local place in SEQ that would be even better.
Thanks.
Post Posted: Sun Apr 07, 2013 6:30 pm
There's a race car bits shop in Belar St Yamanto.
Post Posted: Sun Apr 07, 2013 6:52 pm
Cool, might have to do a drive-by one afternoon.
Vehicle: LJ50V, SJ70
Post Posted: Sun Apr 07, 2013 8:22 pm
I think you'll find that mention of requiring a rear proportioning valve is only needed when running Sierra calipers front AND rear. If you use Pintara or Galant calipers on the back, the piston bore is smaller and in virtually the correct ratio to the Sierra fronts that a proportioning valve is not necessary.
I have Pintara calipers on the rear of the Sierra and the fronts still lock up first, but it is possible to lock all 4 with a hard foot.
Post Posted: Sun Apr 07, 2013 8:34 pm
Agree, my 1.0 LWB Sierra had rear Pintara discs, and no prop valve was needed.
Slightly different brake system on 1.3's though.
Post Posted: Mon Apr 08, 2013 6:16 am
Yep I'd prefer the Sierra calipers all round. More parts commonality, and I have no need or want for a rear axle handbrake assembly.
Post Posted: Mon Apr 08, 2013 7:10 am
I had a mate who turned down the rear Sierra discs, that solved his bias issues.
Some also us less efficient brake pads on the rear, with good ones up front.
Post Posted: Mon Apr 08, 2013 8:55 am
aparently the mini guy over in leichardt coult help out too. as one of the morrisses had them
Post Posted: Mon Apr 08, 2013 11:18 am
Jegs or Summit.. You'll get your stuff within a week and pay half what you would locally.
Post Posted: Mon Apr 08, 2013 1:45 pm
Jegs is the brand I'm running in snotbox. Not sure where to buy them though, a mate gave it to me.
Post Posted: Mon Apr 08, 2013 1:53 pm
Jegs etc are all the same crap. I have one from lowrange for my rear brakes. Vented lux front, vented patrol disc rear with subaru caliper. 80 master
Post Posted: Mon Apr 08, 2013 1:57 pm
problem is that lowrange have drop the ball on customer service in the last couple of months
Post Posted: Mon Apr 08, 2013 2:22 pm
plenty other sellers selling same thing
http://www.outlawspeed.com.au/shop/inde ... dcaf2907e2
Cheap one is probably
Dearer is probably
These things are very generic. few different types, 1000 different brands stuck on them
http://www.aliexpress.com/item/Brake-Bi ... 60960.html
Post Posted: Mon Apr 08, 2013 4:57 pm
Cheers guys!
Allot of the available ones from my resultant searching of whats been suggested all have imperial inlets and outlets (3/16", and NPT fitting etc). Suzuki threads are M10x1.0, so are adaptor fittings typically used, or are people getting new hard line made to suit the different fittings?
Post Posted: Mon Apr 08, 2013 5:01 pm
Just adapt them. Easy as
Post Posted: Mon Apr 08, 2013 7:22 pm
The one I got has npt threads but came with adaptors to tube flare fittings, imperial though. So all you need is a couple of imperial flare nuts and you can cut it into the stock line along the chassis.
Post Posted: Mon Apr 08, 2013 7:33 pm
Considering how much of a nightmare I am currently having trying to find useful adapters online I think this might have to be the way to go. At least the new flare nuts should be cheap as from the local brake shop.
Users browsing this forum: No registered users and 353 guests
