It is currently Thu Oct 29, 2026 10:51 am
Vehicle: hkbjk
Post Posted: Fri Apr 26, 2013 8:04 am
If I put in a WT transfer case (already got it) do you have to change the vacume hubs to manual locking ones?
What is the benefit of manual locking hubs to the vacume are they stronger?
Post Posted: Fri Apr 26, 2013 8:08 am
Hey mate, you should start searching a bit. People have covered this many times.
Vac hubs can be unreliable due to needing a Tcase signal, vac motors all the hoses to be intact and the hubs to be greased.
Where as a manual hubs need to be greased.
To fit to a Jimny front end you will need a spacer some bolts and 12 cone washers. The spacer is cause of the extra lip Jimny's have for the vac operations.
Hope that answers your questions.
Vehicle: hkbjk
Post Posted: Fri Apr 26, 2013 8:13 am
I remembered seeing that you do this mod when you do the tcase swap just not why. That answers it for me thanks.
Users browsing this forum: Google [Bot] and 357 guests
