Hey mate, you should start searching a bit. People have covered this many times.
Vac hubs can be unreliable due to needing a Tcase signal, vac motors all the hoses to be intact and the hubs to be greased.
Where as a manual hubs need to be greased.
To fit to a Jimny front end you will need a spacer some bolts and 12 cone washers. The spacer is cause of the extra lip Jimny's have for the vac operations.
Users browsing this forum: No registered users and 748 guests
