It is currently Wed Oct 14, 2026 12:58 pm
Post Posted: Fri May 03, 2013 5:30 pm
Anyone know what PSI I should expect on a freshly built G16B at idle, and 3000 rpm ??
Post Posted: Fri May 03, 2013 8:45 pm
@3000RPM I believe it should be around 60PSI-ish
What are you getting mate?
Post Posted: Sat May 04, 2013 2:22 am
Suzuki does not spec the pressure at idle - the FSM calls for 46.9~61.1 psi @ 4000 rpm with the engine warm - from experience anywhere between 20~25 psi at idle, depending on how hot the day is, how hot the engine is and your idle rpm.
Users browsing this forum: No registered users and 272 guests
