It is currently Sun Aug 02, 2026 3:05 am
Vehicle: V6 autolocker rear and so much
Post Posted: Wed May 22, 2013 7:15 pm
Can any one post a link or send me in the right direction for a services manual for the SV620 Vitara.
I'm leaking oil from the engine which i suspect its coming from the sump seal, need to gather as much information on Engine pan removal before i tackle it, as i'm unsure whether or not its a gasket seal or simply use the handy blue gasket glue.
Post Posted: Wed May 22, 2013 7:37 pm
my guess is rear main or front crank seal... where is it leaking from?
Post Posted: Wed May 22, 2013 8:31 pm
Wot ee sed - usually one of the main crank seals is the culprit. Easy to eliminate the sump - run your hand around the block just above where the pan bolts up and if your fingers get slippery it's coming from higher up. ;)
Post Posted: Wed May 22, 2013 8:54 pm
I've got one, I'll sort out a link later, the current one seems to be broken:
http://www.rhinoman.org
Post Posted: Thu May 23, 2013 7:15 am
The SV620 supplements are here:
http://www.rhinoman.org/manuals/Vitara/SV620.zip
Users browsing this forum: Google [Bot] and 354 guests
