Vehicle: V6 autolocker rear and so much
Posted: Wed May 22, 2013 7:15 pm
Can any one post a link or send me in the right direction for a services manual for the SV620 Vitara. I'm leaking oil from the engine which i suspect its coming from the sump seal, need to gather as much information on Engine pan removal before i tackle it, as i'm unsure whether or not its a gasket seal or simply use the handy blue gasket glue.
Wot ee sed - usually one of the main crank seals is the culprit. Easy to eliminate the sump - run your hand around the block just above where the pan bolts up and if your fingers get slippery it's coming from higher up.
Users browsing this forum: No registered users and 338 guests
