It is currently Sat Sep 26, 2026 7:17 pm
Post Posted: Sun Jul 14, 2013 6:57 am
Has anyone put a second battery in a abs jimny? I have a few ideas on how to fit one but I don't want to reinvent the wheel if I don't have to.
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Jul 14, 2013 11:56 am
I am in the process of putting mine in the back of the car at the moment Shep. Never worked out a way to fit another one under the hood.
Post Posted: Sun Jul 14, 2013 10:31 pm
If you make up a R/A bracket to relocate your washer bottle, you may be able to put a small battery in that space. If you have a body lift, there might be enough space between the chassis rails and behind the transfer case to install an AGM or sealed battery on its side in a custom made box. It will need protection, it will need to be resistant to heat and as far away from the exhaust as possible. Some batteries are not suitable for automotive applications, or mounting any way other than top up.
Post Posted: Sun Jul 14, 2013 10:51 pm
I reckon I can get a n70 in behind the passenger side headlight.
Post Posted: Mon Jul 15, 2013 4:56 am
I know jimny_Timmy has his 2nd battery behind the seats in his draws.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Jul 16, 2013 1:09 pm
would this work? it moves the bottles so mabie if you chopped it down a bit it would fit around the ABS?
http://www.jimnybits.co.uk/shop/jimny-s ... og_27.html
Users browsing this forum: Google [Bot] and 43 guests
