Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
Posted: Sun Jul 14, 2013 10:31 pm
If you make up a R/A bracket to relocate your washer bottle, you may be able to put a small battery in that space. If you have a body lift, there might be enough space between the chassis rails and behind the transfer case to install an AGM or sealed battery on its side in a custom made box. It will need protection, it will need to be resistant to heat and as far away from the exhaust as possible. Some batteries are not suitable for automotive applications, or mounting any way other than top up.
Users browsing this forum: Google [Bot] and 71 guests
