It is currently Mon Oct 26, 2026 5:14 pm
Post Posted: Mon Jul 22, 2013 12:30 pm
KT is getting a mini makeover in the coming months, part of which is fitting AC. I have the in cabin stuff sorted, I have the under bonnet gear from a coily and hope to be able to use most of that to get a factory look, but where I'm unclear is the choice of compressor. Being driven by the mighty F10a I'm thinking small is best, and I will probably go for something 2nd hand, so do any of you have ideas on what donor vehicle would have an appropriate compressor?
Post Posted: Mon Jul 22, 2013 1:45 pm
From a 1.3 will give you a compressor the right size for the system.
Post Posted: Mon Jul 22, 2013 2:57 pm
I was thinking a G10 swift with aircon might also be suitable. I found this the other day, its the factory install instructions for aircon, if you haven't seen it. Its for LHD but the same applies.
http://www.suzukiinfo.com/sierra/samuraiacinstall.pdf
EDIT: Going by the rock auto listing X90, Swift, Vitara and Sierra all use the same compressor
Post Posted: Mon Jul 22, 2013 3:27 pm
Thanks Jono, that's a good reference, appreciate it.
This is the condensor I'm fitting
http://speedyairspares.com.au/products/ ... 5-235.html
Post Posted: Mon Jul 22, 2013 3:30 pm
No worries, I just assumed you had found a factory under dash aircon unit.
That site has some interesting stuff.
Post Posted: Mon Jul 22, 2013 4:28 pm
I would like a factory underdash unit, in fact I have the coily condensor but the old 1L internals just don't marry up, and so I will use this universal one which will replace the original yet still allow original vents etc, hopefully the only noticeable change is that air will flow from them :o
Users browsing this forum: No registered users and 267 guests
