It is currently Mon Jul 27, 2026 4:30 am
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Oct 09, 2013 7:55 pm
Hey guys... who knows the deal with the commodore engine mounts .do u use both ..for a g13b in a serra ?
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Oct 09, 2013 8:06 pm
Yep A1423 I think you have to trim them.
Post Posted: Wed Oct 09, 2013 8:24 pm
Yer I read cut the pin off .. do they mess with the alignment of the engine and gear box ...it doesn't push the gear box across or anything weird ?
Post Posted: Thu Oct 10, 2013 5:12 am
I've seen a few Sierras fitted with VL mounts. All had G16B's in them and all had issues caused by the mounts. Stekkys was the worst.
I would fit standard Sierra or a burstproof setup like Petroworks.
Post Posted: Thu Oct 10, 2013 5:16 am
Thanks want33s ...yer iv just tried to use the commy mounts and yer it will bolt in with persuadeing but the gear box goes majorly into one side of the torqe tunnel. Iv just bought some more stock sierra mounts for mine :)
Post Posted: Thu Oct 10, 2013 6:58 am
I have had VL mounts on all the G13a/ba sierras I have owned and had no issue. G13b and g16 sierras I used these
http://www.lowrangeoffroad.com/index.ph ... ounts.html
Post Posted: Thu Oct 10, 2013 7:22 am
I ran them with both a 1.3 and G16a. They did make the 1.6 conversion kit a bitch to line up, even the 1.3 has to be played with a bit to get them both on right. It will lift the engine in the bay so take that into consideration if bonnet room is a problem. It slightly rotated my rear gearbox mount which just made it a slightly more annoying fit but it still worked and I never busted either engine mount or gearbox mount.
Post Posted: Thu Oct 10, 2013 7:43 am
I used hilux ones
Post Posted: Thu Oct 10, 2013 8:16 am
I got some D21 mounts and me and Kyzer modified to fit them. A bit too much vibration through them for my liking so I am looking for another solution. Need some donor mounts though - m series.
Post Posted: Thu Oct 10, 2013 8:29 am
tanshi wrote:
I used hilux ones
Got any pics ,
I know u can get a heavy duty cortina engine mount rubber and they are 30 somthing mm thick , a mate of mine has them under a 302 Windsor making some high hp so they seem like an option for strength maybe. ..iv ordered standard 1.3 mounts for know $33 to the door
Post Posted: Thu Oct 10, 2013 8:32 am
i seem to remember is involved some modding to make them fit, but they were heaps strong.
Post Posted: Thu Oct 10, 2013 2:39 pm
i have a vl turbo mount on the passenger side of the motor and stock on the drivers side. cut off the pin and bolted straight in no problems been in there for a year no probs. before that i broke 3 stock ones in a few months.
Post Posted: Thu Oct 10, 2013 6:47 pm
Is engine on slant?
Post Posted: Thu Oct 10, 2013 7:07 pm
i have never noticed it being any different. ie if someone was to look you would never notice it even if you tried.
Post Posted: Thu Oct 10, 2013 11:44 pm
I've got VL mounts on my g16b and the engine fit's in perfectly.
Post Posted: Fri Oct 11, 2013 9:46 am
Mine g16b is sitting on vl mounts but the gear box mount is over to the drivers side by about 5/10 mm, in going to have a play tomorrow morning and iv also know got a new gearbox mount, wich may be part of the problem ....I hope.
Thanks for all ur replys
Post Posted: Fri Oct 11, 2013 3:21 pm
KEENSY85 wrote:
Is engine on slant?
Same as I do mine. Even my jimny!
A tiny slant no real issues caused buy it tho.
Post Posted: Sat Oct 12, 2013 10:01 am
Okay guys thanks heaps for ur help guys :D
I know have one standard new mount on the right and a new comy mount on the left it all looks perfectly strait lol :peaceout:
Users browsing this forum: Google [Bot] and 334 guests
