It is currently Sat Oct 24, 2026 5:53 pm
Post Posted: Wed Jun 04, 2014 7:59 pm
I did my rear bearings and rear axle oil seals about 2000km ago, Within 300km one side oil seal had fail with oil leaking out onto the inside of the rim. Found a spare seal that fit tighter than the original and that sealed it up but not again its leaking and that without any mud wheeling. I've tried looking for a replacement seal but that only list them in the bearing kits.
Any one know or a good seal that i can replace it with?
The seal that came with the bearing kit was NOK seal bc5936e
and the one that also fit and worked was CHO05706 71x51x9.
Any ideas to stop the leaks? Its only very minimal like the diff is still full of oil when i take the drain plug out to check.
Post Posted: Thu Jun 05, 2014 9:30 am
Is the breather blocked?
Post Posted: Thu Jun 05, 2014 9:41 am
Nope clear as anything. Air goes straight through it
Post Posted: Thu Jun 05, 2014 9:59 am
air leaker leaking?
Post Posted: Thu Jun 05, 2014 11:26 am
It leaks sometime but not right now lol when it leaks it comes through the breather hence knowing its not blocked
Post Posted: Thu Jun 05, 2014 1:01 pm
bent axle?
Post Posted: Thu Jun 05, 2014 1:38 pm
Nope didn't look bent at all no signs of anything...
Users browsing this forum: Google [Bot] and 81 guests
