I did my rear bearings and rear axle oil seals about 2000km ago, Within 300km one side oil seal had fail with oil leaking out onto the inside of the rim. Found a spare seal that fit tighter than the original and that sealed it up but not again its leaking and that without any mud wheeling. I've tried looking for a replacement seal but that only list them in the bearing kits. Any one know or a good seal that i can replace it with? The seal that came with the bearing kit was NOK seal bc5936e and the one that also fit and worked was CHO05706 71x51x9.
Any ideas to stop the leaks? Its only very minimal like the diff is still full of oil when i take the drain plug out to check.
Users browsing this forum: No registered users and 132 guests
