Gday everyone I bought my jlx lwb a couple of years ago & the a/c hasn't worked since then. I eventually chased it down to a wire (yellow with blue stripe) not being connected to a temp? Sender. Does this wire double up on temp gauge sernder or does it go somewhere else? Any help or pictures would be appreciated? Thanks Barry
Gday Yep, I've been all over that site & all I can find are wiring diagrams. They show that the wire needs to go to a "coolant temperature sender". The only temp sender I can find is for the gauge. I need to find the physical position of this sender if it is not the one for the gauges. Barry
Vehicle: 92 SWB Vitara
Posted: Sat Jun 21, 2014 5:00 pm
In the thermastat housing their should be provision for 2 temp senders. The front one is for the temperature gauge, the rear one is for the a/c. In my car it has a blank in it that you should be able to pull out and replace with the sender.
Users browsing this forum: No registered users and 49 guests
