It is currently Wed Jul 29, 2026 8:37 am
Vehicle: vitara se416
Post Posted: Sat Jun 21, 2014 11:27 am
Gday everyone
I bought my jlx lwb a couple of years ago & the a/c hasn't worked since then.
I eventually chased it down to a wire (yellow with blue stripe) not being connected to a temp? Sender.
Does this wire double up on temp gauge sernder or does it go somewhere else?
Any help or pictures would be appreciated?
Thanks
Barry
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sat Jun 21, 2014 3:16 pm
http://www.suzukiinfo.com/
All the manuals you will ever need!
Post Posted: Sat Jun 21, 2014 3:38 pm
Gday
Yep, I've been all over that site & all I can find are wiring diagrams.
They show that the wire needs to go to a "coolant temperature sender". The only temp sender I can find is for the gauge.
I need to find the physical position of this sender if it is not the one for the gauges.
Barry
Vehicle: 92 SWB Vitara
Post Posted: Sat Jun 21, 2014 5:00 pm
In the thermastat housing their should be provision for 2 temp senders. The front one is for the temperature gauge, the rear one is for the a/c. In my car it has a blank in it that you should be able to pull out and replace with the sender.
