Got a problem I'm trying to hunt down for a bloke. Pump to activate front diff isn't working. New pump been fitted by previous mechanic. No 4wd light coming on when lever shifted to 4wd, switch working ok. Where is the controller that turns the pump on?
Managed to get the pump working with all my fiddling but the front diff won't engage. Assuming something is broken or seized internally. Still can't get the 4wd light on the dash to work though. If I unplug the pump then the light comes on and stays on.
Users browsing this forum: No registered users and 936 guests
