| Author |
Message |
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Wed Aug 20, 2014 11:36 am |
Not sure if my motor is on its last legs, but it blows smoke on start up and I think is loosing power gradually. Is it likely that the O2 sensor is gunked up of needs replacing? Its also starting (all of a sudden) using 18L/100kms. Which sucks. If anyone can shed some light I'd love to get this sorted. Wilso
atari4x4
 Posted: Wed Aug 20, 2014 11:55 am |
 Wilso, have you pulled the error codes?
31zook
 Posted: Wed Aug 20, 2014 12:11 pm |
Do mark I jimnys have obd ports?
Plus I don't have a scanner
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Wed Aug 20, 2014 12:25 pm |
cleaned the maf sensor recently? worth a go and its only 2 scrws to pull out and a spray with some contact cleaner.
_________________ your daily dose of questionable sanity
JrZook
 Posted: Wed Aug 20, 2014 12:27 pm |
What color smoke? I think it's trying to tell you that its j24+auto time
31zook
 Posted: Wed Aug 20, 2014 1:41 pm |
Haha I wish I was ready to do that yet lol.
Grey smoke
Ill look at the MAF this arvo.
atari4x4
 Posted: Wed Aug 20, 2014 3:40 pm |
31zook wrote: Do mark I jimnys have obd ports?
Plus I don't have a scanner I don't know Wilso, bung your head under the dashboard on both sides? In your engine bay adventures have you seen the little white diagnostic plug? Has 6 ports stacked 3 on 3, but not all are populated.
droverdave
Vehicle: 85 ' Drover
 Posted: Wed Aug 20, 2014 4:06 pm |
18L/100km sais to me your engine is running uber rich which is most likely a sensor issue which is causing the ecu to go into limp mode if it has one, or just causing the ecu to give the wrong fuel or ignition advance leading to your lack of power. To find the dead sensor its either trial and error or find the code. some info in here about finding the codes/OBD port if its refering to the same motor as yours. viewtopic.php?f=5&t=38996
JrZook
 Posted: Wed Aug 20, 2014 4:09 pm |
31zook
 Posted: Wed Aug 20, 2014 6:56 pm |
No, no CEL. Just a seat of my pants feels thing.
Thanks for the link, ill have a look tomorrow arvo as today has gotten away from me...
