It is currently Fri Jul 24, 2026 2:40 pm
Post Posted: Wed Aug 20, 2014 11:36 am
Not sure if my motor is on its last legs, but it blows smoke on start up and I think is loosing power gradually. Is it likely that the O2 sensor is gunked up of needs replacing? Its also starting (all of a sudden) using 18L/100kms. Which sucks.
If anyone can shed some light I'd love to get this sorted.
Wilso Armsup
Post Posted: Wed Aug 20, 2014 11:55 am
Image Wilso, have you pulled the error codes?
Post Posted: Wed Aug 20, 2014 12:11 pm
Do mark I jimnys have obd ports?
Plus I don't have a scanner
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Aug 20, 2014 12:25 pm
cleaned the maf sensor recently? worth a go and its only 2 scrws to pull out and a spray with some contact cleaner.
Post Posted: Wed Aug 20, 2014 12:27 pm
What color smoke? I think it's trying to tell you that its j24+auto time 8)
Post Posted: Wed Aug 20, 2014 1:41 pm
Haha I wish I was ready to do that yet lol.
Grey smoke
Ill look at the MAF this arvo.
Post Posted: Wed Aug 20, 2014 3:40 pm
I don't know Wilso, bung your head under the dashboard on both sides? In your engine bay adventures have you seen the little white diagnostic plug? Has 6 ports stacked 3 on 3, but not all are populated.
Vehicle: 85 ' Drover
Post Posted: Wed Aug 20, 2014 4:06 pm
18L/100km sais to me your engine is running uber rich which is most likely a sensor issue which is causing the ecu to go into limp mode if it has one, or just causing the ecu to give the wrong fuel or ignition advance leading to your lack of power.
To find the dead sensor its either trial and error or find the code.
some info in here about finding the codes/OBD port if its refering to the same motor as yours.
viewtopic.php?f=5&t=38996
Post Posted: Wed Aug 20, 2014 4:09 pm
No CEL?
Post Posted: Wed Aug 20, 2014 6:56 pm
No, no CEL. Just a seat of my pants feels thing.
Thanks for the link, ill have a look tomorrow arvo as today has gotten away from me...
Users browsing this forum: Google [Bot] and 335 guests
