It is currently Tue Jul 28, 2026 11:32 am
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Fri Sep 05, 2014 9:21 am
hey guys
i have a Holden drover (Lwb nt Sierra) that has been re badged it has a 1.3l nt transfer case with the handbrake on the rear output and i am just wondering will normal low range gears from LROR fit in. or will i have to get a 1.3l wt case to put in? just wondering before i order the gears. i know for 6:5:1 gears i need to grind a bit of the case back even in a 1.3l wt case but is it the same in the nt case thanks for the help guys
P.S. its a 1984 model 1.3l
Sam
Post Posted: Fri Sep 05, 2014 9:25 am
My understanding is the cases are the same and only the 1 ltr non switched wont take gears (and the coily transfer )
Post Posted: Fri Sep 05, 2014 9:28 am
yep, they will fit
Post Posted: Fri Sep 05, 2014 9:29 am
when you say non switched what do you mean? the 4x4 light doesn't come on?
Post Posted: Fri Sep 05, 2014 9:30 am
well that made things easier, will the braces and heavy duty mounts fit fine too?
Post Posted: Fri Sep 05, 2014 9:55 am
yep, most will. just need to make sure you don't use ones that mount to the same place as the transfer brake does
Post Posted: Fri Sep 05, 2014 10:16 am
yeah thanks for the help bud :)
Users browsing this forum: No registered users and 389 guests
