It is currently Thu Jul 30, 2026 11:19 am
Vehicle: 1996 Leaf Sierra - Soft Top
Post Posted: Fri Sep 05, 2014 7:00 pm
Okay so I'm about to buy a G16B motor out of a Vitara for my sierra to do the conversion with but the one I have found is coming out of an auto Vitara. Is this a problem at all with wiring or joining the Vitara engine to sierra gearbox? Or is there anything that could cause a bit of extra trouble as it's an automatic?
Thanks and sorry if this have been said! I have read most of the conversion topics and couldn't find any info.
Also I have made a bit of a list of the things I'll be needing to collect before I do the conversion. Can anyone see anything major that I'm missing? I have already started to collect bits and pieces!
-Engine conversion-
Things needed:
• G16B Vitara engine
• Vitara wiring lume
• Vitara ECU/computer
• Vitara speedo cluster
• BenT conversion kit
• New engine mounts
• Sierra SJ80 fuel tank
or
• SWB Vitara fuel tank - need to modify mounts
• Vitara fuel pump
• Vitara thermostat
• Vitara accelerator cable
• Sierra SJ70 starter motor
• Sierra SJ70 clutch/flywheel
• Sierra SJ70 clutch cable
• Falcon 110amp alternator
• High pressure fuel filter
• High pressure fuel lines
• Coolant hoses
• Vacuum lines
• Hose clamps
• G16B timing kit
• G16B water pump
• G16B rocker cover gasket
• Jimny G13BB extractors
• G16B/ G13BB exhaust gasket
And I'm doing PS at the same time:
-Power steering instal-
Things needed:
• Vitara power steering box
• Vitara power steering pump/pulley
• Vitara power steering reservoir
• Vitara power steering lines
• Power steering belt
Thanks heaps for any help at all!!
Thomas.
Vehicle: 92 wt soft top sierra
Post Posted: Fri Sep 05, 2014 8:15 pm
-Engine conversion-
Things needed:
• New engine mounts
or
• Vitara fuel pump
• Vitara thermostat
• Coolant hoses
• Vacuum lines
• Hose clamps
• G16B timing kit
• G16B water pump
Things needed:
Thomas.
After reading that i assume your not interested in my engine anymore
Post Posted: Fri Sep 05, 2014 8:32 pm
-Engine conversion-
Things needed:
• New engine mounts
or
• Vitara fuel pump
• Vitara thermostat
• Coolant hoses
• Vacuum lines
• Hose clamps
• G16B timing kit
• G16B water pump
Things needed:
Thomas.
Still interested, just making sure I'm making the right decision. Not rushing into anything at the moment.
Post Posted: Sat Sep 06, 2014 4:21 am
Oh and that sounds like you got the lot there
Users browsing this forum: No registered users and 296 guests
