It is currently Mon Oct 26, 2026 12:51 pm
Vehicle: 1997 Vitara
Post Posted: Sat Sep 13, 2014 4:00 pm
I have a 1997 Vitara with Calmini suspension installed. Since I have purchased this little truck, I have experienced a whine comi9ng from the rear end. It mainly occurs when I back of at hi speed and under load. With the attempt to use process of elimination I have changed the tail shaft, gearbox and transfer case, and the rear diff. I unfortunately still have this whine. My thought's are it maybe the angle of the rear uni due to the lift.
Has anyone had the same problem and how did you solve it.
Post Posted: Sat Sep 13, 2014 4:31 pm
pic of rear pinion angle & how far in/out is the heim joint wound... actually pics of both would help.
Vehicle: Suzuki Grand Vitara
Post Posted: Sat Sep 13, 2014 6:04 pm
As atari4x4 said will be the rear pinion angle, I tried different adjustments but could not get rid of the noise.
Post Posted: Sat Sep 13, 2014 9:47 pm
I don't think there is anyway to adjust the angle of the diff.
Post Posted: Sat Sep 13, 2014 11:25 pm
what calmini kit 2" or 3"?
the 3" is adjustable by screwing in/out the threaded rod end/heim joint/ rose joint on the upper link to adjust the pinion angle
Users browsing this forum: Google [Bot] and 359 guests
