It is currently Fri Oct 09, 2026 6:39 am
Vehicle: MY2019 Jimny
Post Posted: Fri Jun 12, 2009 2:39 pm
G'day guys,
I picked up some axles that have birfield rings on them - How much grinding is required to make them fit?
Also, the large nut on the hub, does it have to be a deep socket to undo it, or will a regular depth socket do?
Having never swapped a front centre or pulled apart hubs etc, is there anything in particular to watch out for?
Post Posted: Fri Jun 12, 2009 2:54 pm
I use a standard 50mm socket to undo those nuts in the hubs...
Don't know about the grinding as I have never had birfield rings.. I run CrMo axles..
Tip: Do one side at a time so if you stuff up you can look at the other side...
Post Posted: Fri Jun 12, 2009 3:08 pm
if you arent planning on servicing or adjsuting the bearings you dont need to touch that nut
Post Posted: Fri Jun 12, 2009 3:09 pm
Ah ok - Thanks guys.
Post Posted: Fri Jun 12, 2009 4:48 pm
I have the info at home mate on how much to grind off. I'll have a look when I get home and post up if you still need it?
Post Posted: Fri Jun 12, 2009 10:00 pm
Yeah I do Bruce, thanks...
Post Posted: Fri Jun 12, 2009 11:59 pm
lump_a_charcoal wrote:
G'day guys,
I run birfields, you need to grind off an area about the size of a five cent piece in 4 spots(corners) of the nuckle to about a depth of maybe 0.5mm to 1mm. basicly your removing a casting/forging mark in the corners.
The best way I found to make sure you get the right spot is clean out the nuckle and spray a marking paint in there fit the cv and move it around inside the nuckle and look for the scuff marks if you have a die grinder it will take five minutes a side make sure you get all the metal out and stuff a rag in the akle seal. spider tracks birfeilds come with instructions to show you where to grind as well.
If you need I'll have a look and see if I can find them if you like.
cheers andrew
Post Posted: Sat Jun 13, 2009 11:47 am
Hope this works
Post Posted: Sat Jun 13, 2009 12:34 pm
This thread is teh tech!
Thanks Bruceh...
Post Posted: Sat Jun 13, 2009 4:33 pm
No worries at all mate. Glad I could help someone in Tech for a change :-)
Post Posted: Thu Oct 28, 2010 4:59 am
holy grave dig! :D
My question being, do these really work? will it stand up to 33s and welded front diff?
Users browsing this forum: No registered users and 202 guests
