Vehicle: 2" 97 Coily on 30's
Posted: Tue Nov 08, 2016 1:21 pm
Hey, just wondering if anyone could help me out. Could someone send a photo of their 1.6 extractors, where they connect to the exhaust. Is having the a flange/ join a problem? (Does it hit the chassis rail?) Or should I just weld it ? Thanks
Make the extractors fit, weld in a flex tube and a joiner. 1 piece exhaust will suck if you need to do engine work. Without the flex tube the extractors can crack a lot
Joined: Sun Jan 26, 2014 9:03 am Posts: 212 Location: Leschenault, WA.
Vehicle: 2020 Vitara Turbo
Posted: Sat Nov 12, 2016 9:52 am
Used stock Vitara manifold and didn't have a problem using zukparts engine mount kit, Hi-tech extractors fitted with no problem, but that was with cut off and re-fabbed engine mounts.
Users browsing this forum: No registered users and 174 guests
