It is currently Thu Oct 01, 2026 2:44 am
Vehicle: 2" 97 Coily on 30's
Post Posted: Tue Nov 08, 2016 1:21 pm
Hey, just wondering if anyone could help me out. Could someone send a photo of their 1.6 extractors, where they connect to the exhaust. Is having the a flange/ join a problem? (Does it hit the chassis rail?) Or should I just weld it ?
Thanks
Post Posted: Tue Nov 08, 2016 5:09 pm
No photo, but mine are dented to clear the chassis rail. That's with a jimny head & extractors on 1.6 bottom end though.
Mine clear the chassis by about 7mm and duck under the firewall with about 25mm to spare. Passenger foot well gets super hot in summer =)
Post Posted: Tue Nov 08, 2016 7:23 pm
I run stock jimny g13bb manifold
Fits fine, flows just as if not better than 99% of ebay extractors and cost $40
Post Posted: Tue Nov 08, 2016 8:03 pm
Make the extractors fit, weld in a flex tube and a joiner.
1 piece exhaust will suck if you need to do engine work.
Without the flex tube the extractors can crack a lot
Vehicle: 2020 Vitara Turbo
Post Posted: Sat Nov 12, 2016 9:52 am
Used stock Vitara manifold and didn't have a problem using zukparts engine mount kit, Hi-tech extractors fitted with no problem, but that was with cut off and re-fabbed engine mounts.
Users browsing this forum: No registered users and 177 guests
