| Author |
Message |
outterlimits95
Vehicle: 1989 Sierra Tintop
 Posted: Tue Aug 20, 2019 7:06 pm |
G'day lads,
I know this has been covered 3 million times and ive read everything i can read. This issue is pretty simple, the car will not idle on start up, not idle while warm, but randomly idle at 1200rpm.
so far i have: -done timing -replaced ignition coil, leads, plugs -checked timing -checked vacuuming leaks -checked distributor timing what-cha-ma-call-it (mechanic did it) -check compression - 120psi each cylinder -replaced all vac lines just in case -checked choke, working as it should - new radiator and lines, flushed while replacing -check throttle cable for rough spots, grabs, movement, whatever. -sprayed start ya bastard around to triple check for vacuum leaks, nothing found. -mechanic adjusted idle to sit at pretty much bang on 1k which sounded how it should (i know standard idle is around 800-900rpm)
after checking timing car idled like a dream for about a week. The problem cropped its head back up this week and the car just refuses to idle at all now, just dies through the ass.
Stock standard 1.3L sj50 ( engine stock, body not stock)
Any help would be appreciated.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Tue Aug 20, 2019 9:47 pm |
Carby
_________________ ...
bumstein
 Posted: Tue Aug 20, 2019 10:17 pm |
MrRocky wrote: Carby Gotta be the only thing left!! I’m pretty disheartened at the stock carby, better to replace them with something that works better IMO
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Wed Aug 21, 2019 9:11 am |
fuel filter?
long shot, pump on it's last legs. How does the car go at high rev's?
fresh fuel?
HarryHoudini
Joined: Fri Jul 01, 2011 12:34 am Posts: 360 Location: Northern NSW Australia.
Vehicle: Coily.
 Posted: Wed Aug 21, 2019 9:15 am |
bumstein wrote: MrRocky wrote: Carby Gotta be the only thing left!! I’m pretty disheartened at the stock carby, better to replace them with something that works better IMO Yep,plenty of Threads on here and other Forums about carby problems,not just Suzuki,emission era carbs from the 1980's are a nightmare when they go wrong,minute passageways can get blocked and not be fixed with a rebuild. Fit a new carby.
_________________ Regards All from far Northern NSW.
fordem
 Posted: Wed Aug 21, 2019 11:49 am |
Is it just me or does anyone else think 120 psi on a compression test is on the low side?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Wed Aug 21, 2019 11:51 am |
greyghost
Joined: Sat Oct 13, 2012 1:23 pm Posts: 189 Location: VIC
Vehicle: LJ50V 2 stroke
 Posted: Wed Aug 21, 2019 4:07 pm |
anything under 140 is garbage, new engine time
outterlimits95
 Posted: Wed Aug 21, 2019 5:26 pm |
Too easy lads,
Anyone want to buy her, located northside brisbane!
Fuel is fresh, new filter and drives fine with high revs, just idle.
Looks like im up for a new carby. appreciate all the help guys, i'll give it a crack and see how we go
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Fri Aug 23, 2019 6:55 am |
