It is currently Wed Sep 23, 2026 6:49 am
Vehicle: 1989 Sierra Tintop
Post Posted: Tue Aug 20, 2019 7:06 pm
G'day lads,
I know this has been covered 3 million times and ive read everything i can read.
This issue is pretty simple, the car will not idle on start up, not idle while warm, but randomly idle at 1200rpm.
so far i have:
-done timing
-replaced ignition coil, leads, plugs
-checked timing
-checked vacuuming leaks
-checked distributor timing what-cha-ma-call-it (mechanic did it)
-check compression - 120psi each cylinder
-replaced all vac lines just in case
-checked choke, working as it should
- new radiator and lines, flushed while replacing
-check throttle cable for rough spots, grabs, movement, whatever.
-sprayed start ya bastard around to triple check for vacuum leaks, nothing found.
-mechanic adjusted idle to sit at pretty much bang on 1k which sounded how it should (i know standard idle is around 800-900rpm)
after checking timing car idled like a dream for about a week. The problem cropped its head back up this week and the car just refuses to idle at all now, just dies through the ass.
Stock standard 1.3L sj50 ( engine stock, body not stock)
Any help would be appreciated.
Post Posted: Tue Aug 20, 2019 9:47 pm
Carby
Post Posted: Tue Aug 20, 2019 10:17 pm
MrRocky wrote:
Carby
Gotta be the only thing left!!
I’m pretty disheartened at the stock carby, better to replace them with something that works better IMO
Post Posted: Wed Aug 21, 2019 9:11 am
fuel filter?
long shot, pump on it's last legs. How does the car go at high rev's?
fresh fuel?
Vehicle: Coily.
Post Posted: Wed Aug 21, 2019 9:15 am
bumstein wrote:
MrRocky wrote:
Carby
Yep,plenty of Threads on here and other Forums about carby problems,not just Suzuki,emission era carbs from the 1980's are a nightmare when they go wrong,minute passageways can get blocked and not be fixed with a rebuild.
Fit a new carby.
Regards All from far Northern NSW.
Post Posted: Wed Aug 21, 2019 11:49 am
Is it just me or does anyone else think 120 psi on a compression test is on the low side?
Post Posted: Wed Aug 21, 2019 11:51 am
Agreed.
Vehicle: LJ50V 2 stroke
Post Posted: Wed Aug 21, 2019 4:07 pm
anything under 140 is garbage, new engine time
Post Posted: Wed Aug 21, 2019 5:26 pm
Too easy lads,
Anyone want to buy her, located northside brisbane!
Fuel is fresh, new filter and drives fine with high revs, just idle.
Looks like im up for a new carby. appreciate all the help guys, i'll give it a crack and see how we go
Post Posted: Fri Aug 23, 2019 6:55 am
Take it to losfer.
bye
Users browsing this forum: Google [Bot] and 209 guests
