It is currently Sat Nov 14, 2026 8:21 pm
Vehicle: 1982 suzuki sierra ute
Post Posted: Wed Aug 30, 2023 2:10 pm
G'day all, my 1982 LWB NT has a gnarly clunk in the rear end when changing gears and reversing, even when putting through town, it sounds like the diff but we pulled it out and found nothing (sun gears slightly worn) so we put a LJ80 4.9*1 diff in and fix it a bit, but now its even worse, we had a little geez underneath and found the drive shaft looks to be the issue, it has quite a bit of backlash from the slip yoke. if anyone knows or had this issue, some help will be super handy! thanks.
Post Posted: Fri Sep 01, 2023 6:43 am
Uni joints?
Post Posted: Fri Sep 01, 2023 1:38 pm
Unis are all brand new, but is also a worry
Post Posted: Fri Sep 01, 2023 4:19 pm
I've got the same issue in my LWB Sierra. In my case, it's the drum brake / hand brake on the back of the transfercase that is making clunking noises. I'm planning to pull it apart and rebuild it. I hope that fixes my clunking issue.
Post Posted: Sat Sep 02, 2023 3:11 pm
Ahhh ok! That might also be the issue with mine, thanks for telling me that, i might have a look soon
Post Posted: Sun Sep 03, 2023 10:20 am
Yes. 1.0 litres have small driveshafts which are prone to wear. Another source of clunking can be from a cracked/distorted axle housing at the U bolts 1.0 litres are prone to this. Every LWB 1.0 I've seen has required the housing welded up.
Users browsing this forum: No registered users and 74 guests
