[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
project82zute
Vehicle: 1982 suzuki sierra ute
 Posted: Wed Aug 30, 2023 2:10 pm |
G'day all, my 1982 LWB NT has a gnarly clunk in the rear end when changing gears and reversing, even when putting through town, it sounds like the diff but we pulled it out and found nothing (sun gears slightly worn) so we put a LJ80 4.9*1 diff in and fix it a bit, but now its even worse, we had a little geez underneath and found the drive shaft looks to be the issue, it has quite a bit of backlash from the slip yoke. if anyone knows or had this issue, some help will be super handy! thanks.
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Fri Sep 01, 2023 6:43 am |
project82zute
 Posted: Fri Sep 01, 2023 1:38 pm |
Unis are all brand new, but is also a worry
rpmwrx
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1303 Location: Geelong
 Posted: Fri Sep 01, 2023 4:19 pm |
I've got the same issue in my LWB Sierra. In my case, it's the drum brake / hand brake on the back of the transfercase that is making clunking noises. I'm planning to pull it apart and rebuild it. I hope that fixes my clunking issue.
project82zute
 Posted: Sat Sep 02, 2023 3:11 pm |
Ahhh ok! That might also be the issue with mine, thanks for telling me that, i might have a look soon
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sun Sep 03, 2023 10:20 am |
Yes. 1.0 litres have small driveshafts which are prone to wear. Another source of clunking can be from a cracked/distorted axle housing at the U bolts 1.0 litres are prone to this. Every LWB 1.0 I've seen has required the housing welded up.
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 83 guests
